Question about HP Compaq Presario V2000 Notebook
No power and cant be open the program - HP Compaq Presario V2000 Notebook
  • HP Master
  • 32,281 Answers
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Posted on Sep 26, 2009
I cant install any programs on my lap top keep getting cant find environment option.i cant open any program as the admin section not opening.im new at this and dont know what to do as i try to reinst
Your question leaves quite a lot of possibilities open.
I would google Avira. Go to their official web site. Drill down to utilities and download the avira rescue iso. After downloading, burn the iso to a cd. Then reboot your system to boot from the cd. Avira runs a non windows operating system so windows viruses cannot affect it. Try to have the internet connected by hard wire, not wifi.
His should get rid of nasties that may be your problem. Hope this works.
Sep 19, 2014 | Computers & Internet
I cant open my photo explosion on my windows 7, I installed it but I cant find it anywhere what do I do? I shows up on the desktop but then goes away, ive tried re downloading it but I cant find the...
I think you catch some virus, go to control panel, programs and check overthere, uninstall and try to install again, make sure to check in which folder you installing, then go to this folder and try to open this program.
Dec 17, 2013 | Nova Development Photo Explosion Deluxe...
Desktop pc, trying to open attachment on email. file ends in dll. cant find program to open it. tried microsoft, said cant run program on dos mode. can you hep me?
There is a virus problem, you must work full scan of the device and clean it and then restart the machine again.......
Oct 02, 2013 | dll-files.com
Had power cut cant open i tunes
Re-install the iTunes.
Go to Start/Control Panel/Uninstall a program/Select iTunes/Click on Uninstall
Restart your computer
Go to Apple.com and click on iTunes
Download and install them.
I would also recommend you to buy a special device which helps to prevent your computer from turning off when there are power schortages.
Mar 18, 2013 | Microsoft Windows 7 Home Premium 64BIT...
How can i enable my windows xp to run with add-ons enabled? because i cant install adobe flash player. so i cant download videos or watch videos off youtube.
open control panel, open program defaults and set the neccesary changes required for setting default programs.
Sep 28, 2010 | Computers & Internet
Winamp problem
right click on the file you want to open - go to "open with"
than select the program that you do want to open them
it will save the definition
Feb 23, 2010 | Acer Aspire 5100 Notebook
I have a uniden bearcat portable and base I cant figure out how to program it
With the scanner powered ON,
1. Press [HOLD].
“HOLD” appears on the
display.
2. Press [PROG]. CH appears
and blinks to indicate that you
are in the Programming Mode.
To change the displayed frequency,
use [UP] or [DOWN]
while “CH” is blinking.
3. Press [PRIVATE]. “PRIVATE”
appears on the display.
If you want to program it into
another bank, press the
desired bank key. The lowest
open channel appears on the
display.
2 screens alternate to indicate
that open channel is available
to be programmed.
The scanner automatically
selects the lowest open
channel (000.0000) for easy
programming. If all channels
have been programmed (there
are no open channels in the
bank), channel 1 appears.
Use [UP] or [DOWN] to select
a new channel and even overwrite
old channels.
4. Press [PROG] to store the
frequency in the desired
channel.
Note: Press [BAND] to escape
from programming mode before
step 4.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Oct 01, 2009 | Uniden BC350 Base Scanner
Power point cant access c drive as file name is invalid
>what is the file extension
>lets save the file on desktop and open it
>may i know which application are we using to check mail
is webmail, or outlook or some other program
Jan 22, 2009 | Microsoft PowerPoint 2003 Student &...
Up grading Fortec Star (Lifetime II) reciever.
my fortec star reciever is not up grading through (Action HBS link box) to open Showtime program
Apr 25, 2008 | Fortec Star Lifetime ULTRA
Lavasoft adaware problem
Are all you icons at the desktop also gone and are now links but will not open?
If yes pls post back that we can provide you with the solution.
Kind regards.
Feb 13, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
