Question about LG WM-12230FB Front Load Washer
What do I clean my washer with in between washloads to keep it clean and smelling good using cleaners around my home?
    President:
  • 1,185 Answers
Clean out the detergent dispenser and the drain trap first
Then
Put a strong solution of washing soda into the machine before you set it away without a load and on a hot wash (Do not put detergent in)
Let the machine do a full cycle and then leave the door open to let it dry out
You may have to do this twice to get rid of the odour
Also try using old fashioned soap powders which contain bleach and soda.
There is a bacteria build up in your machine due to low temperature washing
Posted on Sep 26, 2009
How do you clean the pump in lg washer wm0642hw
I recently cleaned mine - the wrong way - so I hope this will help. I went in through the back of the washer and disconnected the pump and cleaned it and put it back, but it was very cramped and small. Then, when I ordered the part from Home Depot - I found a video attached to the part showing the correct way to remove and clean the pump. It showed step by step how to take off the top panel and the front panel and get to the pump without crawling through the back of the machine. Home Depot parts are good, too because you can return them up to one year later. I don't have any connection to Home Depot but they have the best videos. Go to homedepot.com/appliancerepair.com and look around for information on you machine and you should be able to find the link. I will look in my files and see if I kept the information and send in the next post.
May 30, 2014 | LG WM1814CW Front Load Washer
We have an older model freezer. The door was left open and we had cleaned up the mess. Now we have a horriable smell around the exterior of the freezer. The interior does not smell. Do all freezers...
Have it clean and use a appliance cleaner that has fragrance to smell it good again.
You must eliminate the source of horrible smell.
Then apply the cleaner on rags, wipe it around the freezer exterior.
Some freezer do have pan and some don't have, so you should look for it carefully.
Good luck.
Jun 26, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
Washer smells like mildew after a load of wash, clothes smell.
Use a washer cleaner like AhFresh (all three tablets) with the tub clean cycle, no clothes in the washer. Now, only use 1 to a maximum of 2 tablespoons of HE laundry detergent per cycle. Due to low water consumption of these machines, you must adjust soap usage or odors will result. It may also help to leave door open for a hour or so after cycle is finished to allow inner tub to dry completely.
Jan 12, 2011 | LG WM-2277HW Front Load Washer
My Duet washer stinks so much. The wash does not come out smelling good. It is clean but it doesn't smell good. I do use those cleaning tablets but it still stinks. It has over-suds many times where...
I have found that using a l/4scoop of oxi cleaner any brand will do along with my regular wash detergent helps keep the odor under control . I leave my door open to the washer when not in use. Occasionally I will clean under the gasket with a mild cleaner. Remember the front loaders use less water and therefor less detergent. Good luck.
Sep 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My dishwasher has a foul/ garbage like smell during/after running. Dishes do come out clean but the smell is really bothersome and it sometimes doesn't fully drain.
goto your nearest home depot they sell a product called affresh you use it on dishwashers there is also another version for frontload washers use this on your washers hotest cycle this removes mostly all smells if the smells persist you might want to check around the chopper area to see if you have any food enlodged around the chopper
May 18, 2010 | Whirlpool 24 in. DU900PCD Built-in...
How to get rid moldy smell in LG Front loader washmachine?
There are several cleaners for front loading washers on the market, such as affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, and tide washer cleaner. Clean out the filter located behind the access door at the lower left front of the machine, then, if your model has a tub clean setting, use that with one of those cleaners, if not, use one of those cleaners with the longest, hottest cycle. If things were very bad, you may have to clean it twice. Now, after it is cleaned out,.....STOP USING SO MUCH SOAP ! Use only one tablespoon of HE laudry detergent per cycle, and only one teaspoon of fabric softener if you use that. (Note: Bath towels, used only to wipe off clean bodies, then tossed into the laundry are not dirty enough to require soap usage, and should never have softener used on them) The odors in your washer are caused by a build up of soap and fabric softeners on the inside of the washer's drum. Also, you may have a build up of soap or fabric softener on your clothes. Wash them again once with no soap or fab softener to rinse them out.
Mar 17, 2010 | LG WM-2277HW Front Load Washer
I HAVE FRONT LOAD LG WASHER - CLOTHES ARE SMELLING -- CAN WE USE 2 CUPS CLR & RUN WASHER WITH NO CLOTHES TO CLEAN WASHER DRUM & DRAIN HOSES. IS THERE A BETTER SOLUTION TO PREVENT THIS PROBLEM
Here is a response I recently gave to a person posting a similar problem. You do not state your model number, so: If you have a tub clean cycle, use that, if not, use the longest, hottest cycle with no clothes and a front load washer cleaner like Ahfresh, Washer Cleaner, SmellyWasher Cleaner, Tide front load washer cleaner, or Whilaway hot tub cleaner. Clean the tub gasket area by the door and remove the filter and clean it out also before you run the clean cycle. You may have to run the cycle with a cleaner twice to remove all the built up soap scum inside the washer. Now, after the washer is clean, USE ONLY ONE TO A MAXIMUM OF TWO TABLESPOONS OF HE LAUNDRY DETERGENT PER CYCLE !!!! (and no more than one teaspoon of fabric softener per cycle, if you use it)
Comments: Jul 21, 2009- Well, with that model I'd guess you are in the UK, and I don't have parts breakdown or service info on those models, but I'd run the front load washer cleaner through it. Not sure which ones are available over there. You could check out http://www.smellywasher.com/ for one possiblity. The big thing is that these machines use very little water, and many of the newer soaps are 2x or 3x concentrated, so you have to use very little soap. (much much less than the soap manufacturers suggest) in order to rinse all the soap residue out of the clothes and prevent it from builing up in your washer and causing odors. (oh, by the way, that one cleaner I listed as Washer Cleaner is actually " Washer Magic ") 73b1c2a.jpg fb3071a.jpg
Jul 29, 2009 | Washing Machines
My water has been smelling of sulfur. The clothes I was end up smelling of BO after being worn for only a short time. It isnt that the person is smell it is the clothing. Is there something to be added to...
I found that WasherFresh worked better then the Affresh.  What I really did not like is you cannot touch the Affresh tablets, WasherFresh is contained in a pouch and is not harmful to touch, because of the disolving pouch containing the chemicals.  Also after reading the package the chemicals are not harmful to the environment.
WasherFresh removed the odor causing buildup and I now use it monthly as a preventive maintenance.
Sep 30, 2008 | Estate TAWX700JQ Top Load Washer
LG WM-12230FB Front Load Washer Logo
116 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
