Question about LG LH-D6230 System
DVD player stopped playing DVD disk. When I load disc player shows Reading then No-Disc. Model of player is LG LH-T553TB
  • LG Master
  • 5,138 Answers
You either have dirty laser beam if so buy disc cleaner at wal-mart or
your Laser head is Bad for that call Mats 1-800-628-1118
Posted on Dec 09, 2009
My LG home theater model LH-W9656. isnt playing
The DVD drive in the player may need to be cleaned but it is more likely that the laser source in the drive has failed and the drive will need to be replaced.
Oct 11, 2014 | Audio Players & Recorders
Put my p-1500 in our RV. Tested with a blueray disk and worked just fine. Wanted to show wife, but it would not play any blueray. but will play standard hi-def. Any ideas?disks. Any ideas
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU, optical pickup unit contain lasser bean NOT reading the TOC disk +Syscon can be defective, you must go to the repair shop TV for fix it
Jul 16, 2012 | Samsung BD-P1500 Blu-Ray Player
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
No audio and video comes out,but the player is reading the disc
Clean your lens with disk clear! Otherwise you want to change your lens in DVD player!
Jun 19, 2008 | LG DP170 Portable DVD Player
Shows Loading menu after switch ON and nothing comes out as results
looks like it has a problem reading the disc
what sort of disc are you trying to play
try with an original DVD and see the results
May 26, 2008 | LG DVD 6183 DVD Player
Dvd video player
Your DVD player is having a problem reading the disc. This is what is accounting for the pausing and the slow loading times...especially if it plays other movies without hitches. Even if the DVD is cleaned, some scratching on the disc will prevent it from being viewed properly. Blockbuster shoudl give you another disc to try of the same movie if you ask. Also, you can try getting a cleaner for your DVD player to remove dust and help it read discs better.
Dec 26, 2007 | Toshiba SD-3980 DVD Player
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Various LG DVD Player
Some models of PIONEER cd players had radio frequency problems that caused them to work on and off. Are you near any radio or braodcast towers? Poorly shielded power supplies cause this as well. A weak laser diode in the pick-up assembly in model runs could be the problem. You might want to Google the model number and see if this is common for these units.
Apr 27, 2007 | LG DK 9411P DVD Player
LG LH-D6230 System Logo
176 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
