Question about Dell Latitude D610 Notebook
Dell latitude D610 laptop
My laptop always hang and after it the usb port no longer reconize it... then i've to shut down and reopen to continue my works... sometimes I got fed up....
amirul from malaysia, perlis
  • amirulb_cik Sep 27, 2009
    thanks for the solution , I've tried checked the BIOS setting and default it...but I still cannot find device manager to find flag as told... sorry cause I'm not very good with computer... thanks again
  • 788 Answers
You may be using the wrong USB port for the device.
Try disconnecting the USB device, restart the unit and use the rear USB port.
It sounds like you are having a conflict with one of your devices. example: using two mouse, USB2 device, running on a USB1 supported port, external Hard disk or drive setting not configured correct.
If you are still having problems, check the BIOS setting and reset to default. Save and restart unit.
Next, check your device manager for flags.
If you see anything outstanding, remove it and reboot.
Once completed, try the USB port and see if your device is usable.
Next time you may want to list the device and your operating system used, to help the tech understand your problems.
Hope this helps you.
Posted on Sep 26, 2009
Can't restart windows 7 on my dell d610, did a format on the hd, re-loaded the windows 7 disc, everything runs great until I shut it down then it won't restart
Recently a put windows 7 on my latitude d610 only problems I had were incompat. Drivers (wifi, sound, graphics.) all were fixed with googling those drivers with windows 7 because this hardware is not compatible with 7 but seeing as it is a restart thing,
Check the drivers u have installed try to see if any need updating or are no compat.
Nov 19, 2012 | Dell Latitude D610 Notebook
My Dell Latitude D610 keeps shutting down
Get a can of compressed air and clean out all the vents and fans. You can also use a vacuum with a hose attachment to clean it. You also might want to get a laptop cooler.
Jun 30, 2012 | Dell Latitude D610 Laptop Computer -...
When I try to turn on my Dell D610 Laptop it immediately shuts off.
Hi
Try to remove the battery, hold on power button for about 50-60 seconds, then plug-in the charger and turn the laptop ON, see what happens
Please tell us your results
Good Luck
May 14, 2011 | Dell Latitude D610 Laptop Computer -...
When I unplug the printer from my Dell Latitude D610 laptop, the battery icon appears on the bottom right hand corner instead of the "ON AC power" icon and the computers shut down due to a low battery....
Your AC power supply is not providing power - The printer is supplying your laptop with power via the usb port. When you unplug the printer, the laptop runs on battery until it goes dead. You will need another AC power supply,
Good Luck
Oct 03, 2010 | Dell Latitude D600 Notebook
How to use touch pad dell latitude D610
The touch pad on a Dell Latitude D610 works much the same as with other laptops. You can move your finger around the pad to simulate the movement of a mouse, and it will cause the pointer to move across the screen. You can also tap on the touch pad (gently) to "click" on a file, folder, or other item. The touch pad on a D610 doesn't have a hardware switch like some other laptops do so that you can turn it on or off -- it's just always on.
Aug 08, 2010 | Dell Latitude D610 Notebook
I want to know how to tell if my Dell D610 has the hardware for bluetooth
Nope...it seams that this model do not have any blue-tooth port ..but just a infrared data port ..so if you need to use blue-tooth on it you have to get a blue-tooth USB adapter ..and use it on the usb port ..
http://cgi.ebay.com/2x-Tiny-Bluetooth-V2-0-EDR-Dongle-Wireless-Adapter-A2-/260605992227?cmd=ViewItem&pt=PDA_Accessories&hash=item3cad53dd23
May 20, 2010 | Dell Latitude D610 Intel Pentium M 1.6GHz...
My Dell D610 is always on when I get to work
if you are using Windows Vista, you might haven't shut down your system. Make sure that you did click the Shut Down link at the menu.
Jul 09, 2009 | Dell Latitude D610 Notebook
Dell D610 Latop screen wont resume after it has been shut
it is possible that the latch is sticking. located under the lid.
try pressing the small button, with a small blunt screwdriver.
Failing this, adjust the settings in My Computer/Control Panel/Display settings or Similar. If they,re adjusted to hibernate/sleep/shut-down computer, when i close the lid.
this is where the problem will be. Try changing to Do-Nothing or similar.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 09, 2009 | Dell Latitude D610 Notebook
Dell latitude D610 and 1901 FP monitor
Did you hold down the Fn key and press the function key for the external VGA port? It should cycle as LCD only, LCD and VGA, VGA only and then back to LCD.
Dec 28, 2008 | Dell Latitude D610 Notebook
Dell Latitude D610 Notebook Logo
227 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
