Question about Brother IntelliFAX 770 Plain Paper Thermal Fax
Cover page, how can I turn it off - Brother IntelliFAX 770 Plain Paper Thermal Fax
    Problem Solver:
  • 5 Answers
Press MENU-select FAX-SETUP SEND-COVERPAGE SET UP-and select TURNED OFF the option.
Posted on Sep 26, 2009
  • shahukollam Sep 26, 2009
    press MENU-select FAX-SETUP SEND-COVERPAGE SET UP-and select TURNED OFF the option.
How do i print a confige page on a dell 1720
Turn off the printer
Open the front cover
Press and hold the Continue button as you turn on the printer - all the lights will cycle
Release Continue button and close the front cover
Press the Continue button until the lights cycle and the configuration page will print
Jun 25, 2014 | Dell 1720dn Laser Printer
Light bulb replacement
https://www.google.co.uk/search?q=Hitachi+CP-X253+bulb+replacement.
Fourth result.
"User manual" link on that page.
Page 48 of that document.
Turn off projector and remove power, undo screw on cover, take cover off, undo screws on bulb housing, remove bulb, put new bulb in, do screws up, replace cover, do up its screw, reconnect power and turn projector back on. Go into menu, advanced, option, lamp time, and push the up button to reset hours.
I literally just read that out of the manual.
Jan 30, 2014 | Hitachi CP-X253 Projector
I forgot my bios password compaq presario 900 password bios cen you help my
Before removing the RTC battery, follow these steps:1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn thecomputer on, and then shut it down through the operating system.2. Disconnect all external devices connected to the computer.3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet andthen unplugging the AC adapter from the computer.4. Remove the battery (see Battery on page 34).5. Remove the following components:a. Hard drive (see Hard drive on page 37)b. Optical drive (see Optical drive on page 44)c. Switch cover and keyboard (see Switch cover and keyboard on page 46)d. Display assembly (see Display assembly on page 50)e. Top cover (see Top cover on page 55)f. Fan (see Fan on page 58)g. System board (see System board on page 60)Remove the RTC battery:1. Turn the system board upside down, with the audio connectors toward you.
found here: http://h10032.www1.hp.com/ctg/Manual/c01295803.pdf page 65. you'll have to pull the battery for 5 minutes and then reinstall and all cmos passwords should be cleared! good luck
Jan 27, 2012 | Compaq Presario Notebook
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Cartridge error,refer to devise documentation to troubleshoot
Hello
Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move on
Remove the cartridge and use a clean, lint-free, dry cloth to gently wipe the contacts.
Wipe from the top of the contact to the bottom. Do this for each contact.
Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
Turn on the HP printer, open the cover and remove both the black and color cartridge. Close the cover.
Remove the power cord from the outlet and disconnect the cables running to the computer and/or router. Wait one minute, and then plug in the power cord and then the cables.
Open the cover and install the black and color ink cartridges. Turn the printer on.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, you will need to buy new ink cartridges. Office Max or Wal-Mart have ink cartridges for almost every model of HP Deskjet, Photosmart and Officejet printers.
Jun 10, 2011 | HP Officejet 5610 All-In-One InkJet...
New out of the box and the cover for the batteries will not open? Does the cover screw off? I know it is counter clockwise but it will not turn???
from what i read i think you need to apply pressure to the compartment then turn counter clockwise .
check out the manual link here , page 7.
on the link page just type the numbers shown below , you don't have to give email
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Feb 09, 2011 | RCA WHP141 Consumer Headphones
Hi, We have a Konica-Minolta 7255 that is printed to. Every time a print job is sent, a cover page is generated. I cannot see how to turn that off, the documentation does not address it and the Konica...
Are you using the same software program when you print? If so, go into the software, printing options. Often, there are printing options that you can set up just by clicking a little box that will turn off the cover page feature.
Sep 02, 2010 | Minolta Office Equipment & Supplies
Can't use personal cover page
Go to the Cover Pages.
Select your cover page.
Right-click, select "Set as default"
www.getfaxing.com/winfax
Jan 28, 2010 | Symantec WinFax Pro for PC
Turning off Separator Page/Cover Page when printing
Go to the printer properties page for that printer and choose options. You'll find one of them is for a separator page. Just select no separator and ok the selection.
Mar 14, 2009 | HP Photosmart C5180 All-In-One InkJet...
Brother IntelliFAX 770 Plain Paper Thermal Fax Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
