Question about Microsoft Xbox 360 Console
If got a red flashing light where the on button is and it says on th screen system error contact xbox customer support????????????????
  • Linda Hazelgrave
    Linda Hazelgrave May 11, 2010
    hi, can you tell me what the error code number is please. is it e73, or e74, or something else thanks
  • Linda Hazelgrave
    Hi can you clarify what service number is on screen, im guessing maybe E73 or E74?? if you can clarify i might be able to help you further www.xboxrepairkit.co.uk
    Genius:
  • 1,234 Answers
Hello Sir
Xbox 360 Repair – Want To Beat The Red Lights And Get Back To Gaming? Read This! If you are looking for a way to repair your Xbox 360 from home without having to wait for 4 weeks and have to pay out a lot of money for repair then this blog post will tell you how to do this.
You see the problems are caused by overheating and the main problem is the Xbox 360 3 red lights however you may also get disc reading problems, freeze ups, 2 red lights and 1 red light error codes as well.
So if you get these problems what can you do to perform Xbox 360 Repair?
Well you can send it in and they will repair it for you however this will take about 4 weeks and cost you money for the repair as stated above.
What a lot of gamers are doing is taking the matter into their own hands and performing Xbox 360 Repair from home.
Now this sounds a lot more difficult then it actually is and and as long as you stop the heat build up you will be able to play your games.
To do this you can use a good Xbox 360 Repair guide that will show you how to stop these errors from home and the best thing is that all you need is a few household items.
There is an Xbox 360 Repair guide that will give you step by step videos and a full walk-through for all of the errors so all you need to do is follow through and you will be able to perform Xbox 360 Repair at home with ease!
Check out the full guide and see how easy it is to fix:
Xbox 360 Repair
Posted on Aug 29, 2010
4 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: XBox 360 Console Problem
this refers to a hardware failure, see below http://support.microsoft.com/kb/906937?sd=xbox
Posted on Sep 10, 2007
  • 124 Answers
SOURCE: 360xbox one red bar flashing E-74
First check your AV cable. Unplug it, put it back in, turn back on. If that doesn't work, long story short, call support (18004myxbox).
Error explanation below:
E-74 - There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement (error 102)
102 error - Error in the "Digital Backbone" (CPU/GPU/RAM), this is usually caused by a cold solder joint between the GPU and the mainboard.
There are two theories to fixing this one deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced.
Posted on Jan 22, 2009
darktowernz
  • 191 Answers
SOURCE: system error
this is known as the red ring of death,no worries it can be fix .becouse xbox get hot it courses the cpu to lose contact on 1 of its corners.
this link is to my usendit account its the step by step to repairing the red light error.there are 2 ebooks inside .its will be there for 7 days or 100 downloads . https://www.yousendit.com/download/THE2b3BORkUrV3lGa1E9PQ.
Posted on Mar 12, 2010
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
1 red light on xbox 369
hi, here follows a possible solution from Microsoft support:
One light on the ring of light around the power button on your Xbox 360 console flashes red.
You might also see the following error message on your television screen or monitor: System Error. Contact Xbox Customer Support. This message is followed by an error code in the format of "Exx," where xx is a two-digit number.
Note If you see error code "E74" on your screen, click the following article number to view the article in the Microsoft Knowledge Base: 941377 E74 error appears when you use your Xbox 360 console Back to the top
CAUSE A single flashing light might indicate a hardware failure on your Xbox 360 console. Back to the top
THINGS TO TRY Step 1: Disconnect and reconnect all cables a. Turn off your Xbox 360 console. b. Unplug all memory units, controllers, and accessories from your console. c. Unplug everything from the back of your console, including power and video cables. d. Unplug your power supply from the wall, and then unplug the short cord from the power brick. e. Plug everything back in. Make sure that you make all connections firmly.
f. Turn on your console. If the problem still occurs, go to step 2. Back to the top
Step 2: Remove the hard drive To see whether the problem involves the Xbox 360 Hard Drive, temporarily remove the hard disk unit. If your Xbox 360 console does not have a hard disk, go to step 3. To remove the Xbox 360 Hard Drive, follow these steps: a. Turn off the console. b. Locate the hard disk on your console.
c. Press the release button on the hard disk, and then lift the hard disk from the console.
d. Turn on your console. If these steps resolve the issue, reattach the hard disk to verify that the error occurs only when your Xbox 360 Hard Drive is connected. If this is true, contact Xbox customer support to order a replacement hard disk. To contact Xbox customer support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 3. Back to the top
Step 3: Disconnect any memory units a. Turn off your Xbox 360console. b. Unplug any memory units attached to your console. c. Turn on the console. If these steps resolve the issue, reattach the memory units to verify that the error occurs only when a memory unit is connected. If this is true, contact Xbox Customer Support to order a replacement memory unit. To contact Xbox Customer Support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 4. Back to the top
Step 4: Request a repair If the previous steps do not resolve your single flashing light issue, there are no additional troubleshooting steps and your Xbox 360 console must be repaired at our service center. https://myservice.xbox.com/it-it/Pages/welcome.aspx
Jul 31, 2010 | Microsoft Xbox 360 Console
System error wen i pluged my xbox in red light is showing on start button screen says system error contact xbox customer support
Feb 26, 2010 | Microsoft Xbox Console
1 flashing red ring
The lower-right quadrant of the Ring of Light flashes red on the front of your Xbox 3602.gif console. You also receive the following error message in multiple languages on your television screen or monitor:
System Error2.gif. Contact Xbox Customer Support. This message begins with an error code in the format "Exx," where xx is a two-digit number.
The following indicator will flash on and off repeated on the front panel of your Xbox 360 console:
If one red light is flashing and you receive a different error message2.gif or error code than those that were described previously or you don’t receive an error message or code, your console may be experiencing a different issue. In this case, see "References/links."
This problem occurs when your Xbox 360 console experiences a hardware failure.
  1. Turn off your console, disconnect and reconnect all cables, and then turn on your console.
  2. If an Xbox Hard Drive2.gif is attached to your console, turn off your console, and then remove the Xbox Hard Drive. Turn on your console, and test for the error. If the error does not reoccur, turn off your console and reattach the Xbox Hard Drive. Run alternate additional tests by having the Xbox Hard Drive connected and disconnected to see whether the error occurs only when the Xbox Hard Drive is connected. For more information if the on-screen alphanumeric error is E67, click the following article number to view the article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/ ) One of the lights on the Ring of Light on the front of your Xbox 360 console flashes red and you receive one of the following error codes and message: "E67, or E68, or E69. System Error. Contact Xbox Customer Support"
  3. If an Xbox Memory Unit (MU) is plugged in to your console, turn off your console, and then remove the Memory Unit. Turn on your console again, and test for the error. If the error does not reoccur, turn off your console and reinsert the MU. Run alternate tests by having the MU connected and disconnected to see whether the error occurs only when the MU is connected.
  4. If this problem continues to occur, contact Xbox Customer Service. Note If the agent cannot help you resolve this problem, you must return your console to Microsoft for repair.
Additional support loadTOCNode(2, 'moreinformation'); If the steps in the previous section did not resolve your issue, your console may have to be repaired. For more information about how to start the online repair process, please visit one of the following Web sites:
U.S. customers - Online console repair
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
Nov 11, 2009 | Microsoft Xbox 360 Console
1 RING
Outside the United States - Online console repair
Oct 09, 2009 | Microsoft Xbox 360 Console
My xbox 360 has error 74
The E74 malfunction is a problem believed to be associated with the system's video output cables and/or hardware scaler chip. The problem involves unusual screen patterns, the appearance of an on-screen error message, and finally a flashing red light in the lower right quadrant of the power ring. When a system suffers from the failure the on-screen message reads "E74 System Error. Contact Xbox Customer Support."
You could send it in to Microsoft of you can follow the steps as outlined in this You Tube video.
Mar 21, 2009 | Microsoft Xbox 360 Console
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
An error message comes on screen when thew xbox 360 is turned on as well as it says up the top (system error .contact xbox customer support )also three red lights flash on and off
This is either an error code or the 3 red lights of death. If it is the 3 red lights, and not an error code, you will be under the extended warranty. If it is an error code, hope u are under your origional warranty.
May 09, 2008 | Video Game Consoles & Games
Red light flashing on the bottom right of power button. error is E68
Hi burnzcity,
It seems you have an issue with a Xbox 360. So, according to Microsoft, one red light flashing means you have a system error and suggest you contact Xbox Customer Support. Here is a link that should provide you some assistance.
Sincerely,
Agent Xiong
Sep 10, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
77 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
