Question about Pentax Optio E30 Digital Camera
Pentax Optio E30: how to unlock the "secure button"?
Camera &SD-card shows "Lock-secure"-symbol,evenwhen changing SD-card.ManualCD shows how to lock,but not how to "Unlock" !
sparkyuiop
  • 91 Answers
SOURCE: pentax optio e30 lock icon....
Yeah had me baffeled too. Press the 'menu' button then the 'trash / green' button, one after the other. It unlocked mine.
Posted on Apr 25, 2008
SOURCE: Unlock Pentax Optio S5z
Thank you sooo much *bsho* I had this exact same problem on my camera for about 3 weeks ,and it was really making my angry!.. Thank you so much for your solution it worked for me!
Posted on Sep 19, 2008
  • 11967 Answers
SOURCE: how do I unlock the memory card?
Move the slide switch on the side of the card.
Posted on Nov 11, 2009
SOURCE: Hi, My Pentax Optio E30 has come up with a lock
If it's like mine just was, it's probably stuck in green mode. If that's the case, just hold the delete button for a bit and it should go away and allow menus again.
Posted on Dec 27, 2009
lock123
  • 6831 Answers
SOURCE: How to unlock card in pentax optio Says Card
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 22, 2010
Card unlock pentax optio
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 10, 2013 | Aqua Pentax Optio S12 Digital Camera
The memory card on my pentax optio camera is locked. a yellow key appears. i found the display showing the key but cannot find the function to unlock it
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 25, 2010 | Pentax Optio E30 Digital Camera
Hi i have a pentax E30,after taking a picture it says the card block and does not show the picture taken it will also say the is no image
Do you know that the SD card has a little switch on its side?
It is a small sliding thing on the other side from the cut out corner.
If this is in the lock position it will stop you saving your pictures to the card. This is to protect pictures that you want to keep.
To save pictures to the card the switch must be in the up position.
Jan 16, 2010 | Pentax Optio E30 Digital Camera
When ever I turn on the camera, the display shows "card locked". I can hit the > button and it appears to unlock it, since pictures now show up. But, whenever I try to do anything else it locks back...
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 11, 2009 | Pentax Optio 60 Digital Camera
Hi, My Pentax Optio E30 has come up with a lock symbol on screen when I push Menu or Mode. Nothing I can do will remove it and it's not mentioned in the manual! Would appreciate advice if you knowhow -...
Sep 27, 2009 | Pentax Optio E30 Digital Camera
Pentax digital camera optio s memory card locked
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 25, 2009 | Pentax Optio E30 Digital Camera
SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Feb 22, 2009 | Pentax Optio E30 Digital Camera
Unlocking memory card
http://www.pentax.de/downloads/photo/uk/Optio%2060/Optio60_Manual_web.pdf
pg 17 at the bottom shows how to unlock the card, but it is simple, take out the memory card and on the side of it will be a little tab which can slide, slide it off the lock position and it should work
Mar 18, 2008 | Pentax Optio M10 Digital Camera
Pentax optio e30 lock icon....
Feb 21, 2008 | Pentax Optio E30 Digital Camera
Card NO formatted
If u get a lock(A small switch on the left side of the card) on ur card try changing its position.Move it to other side.
Oct 25, 2007 | Pentax Optio E30 Digital Camera
Pentax Optio E30 Digital Camera Logo
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
