Question about iRiver T30 MP3 Player
Doesn't turn on
I was updating firmware from 1.3 to 1.7, it frooze at the 50% point
I disconnected it from the usb, since than it wont turn on.
I tried taking out the battery, tried a new battery; but no luck
Re: Doesn't turn on - iRiver T30 MP3 Player MP3 & Digital Media Players
Same problem here... this suxxx
Posted on May 03, 2008
Re: Doesn't turn on
I just had the same problem: froze at 50%, so i unplugged the player, and now player won't turn on. tried at least 8 new batteries. anyone know what's up?
Posted on Mar 06, 2008
0 characters
3 Points
My view wont do anything, when i turn it on the only thing it does is turn the dial light blue, nohing else, when i plu it in, nothing. the blue light will stay on for however long the battery lasts, is...
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Dec 27, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa mp3 player wont come back on turn it off while still connected to computer usb chord
Try this? 1.Push the hold switch towards the headphone jack so you see orange
2.Press and hold record on the left of the player
3.With record still being held down, plug into the computer
4.Once you see welcome to recovery mode on the screen of the player, let go of record
At this point you can reload the manual firmware by copying the firmware files to the detected removable disk.
Firmwares- Version 1 Version 2
Download the correct version or else it will render your device useless.Version can be found on the back plate at botton right.. Extract the downloaded file and transfer the contents to removable disk detected.After transferring,disconnect the player and let it upgrade the firmware
Sep 01, 2009 | SanDisk Sansa e260 MP3 Player
I have sansa sandisk e 260. last time, after charging it in my computer, i plug it out without having safety mode in the computer. After then i can not open my disk. when i try to turn on pressing on Menu...
1. Download the Sansa firmware.
2. Turn the player off.
3. On the top of the player is a Hold switch located.
Move it to the right so you see "Orange".
4. On the left hand side of the player is a Record button.
Press and hold the record button while connecting the player to the computer.
Continue holding the Record button until you see a new icon under "My Computer": named "16MB FORMAT".
Once you see that icon release the Record button.
5. Drag and drop the download firmware files to your player (16MB FORMAT).
6. Disconnect the player from USB cable.
Several things will be displayed.
When you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
Otherwise download the Sansa Updater and start follow the points 2-4 and start the Sansa Updater.
After updating the firmware follow point 6.
Jun 08, 2009 | SanDisk Sansa e260 MP3 Player
My rca mp3 wont turn on
1 have it into usb device
2 hold down the play button.
3 update the firmware from RCA website.
Jan 10, 2009 | RCA M4204 MP3 Player
Wont turn on
You can reset the player without losing the music, but Repairs and firmware Updates will result in songs being erased.
Make sure the hold/lock switch is not activated.
If it is not, then try a different USB port on your computer.
If you get the same result:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Dec 27, 2008 | Philips SA3025/37 Flash MP3 Player
My creative zen has froen and wont turn on
Try another PC or another USB port
Make sure the hold/lock is not engaged
Check for firmware update on Creative's website
Get Recovery Tool from creative
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If all else fails, check with this guy:
Have fun!
-Tha Mp3 Doctor
Jul 06, 2008 | MP3 & Digital Media Players
My videos wont convert i need help!
you need to go under settings then click on usb modes then change the mode to msc. if you dont have the option of usb mode, then do the following:
1) Download the sansa firmware updater from the sandisk website (
2) The program then turn off your sansa. (unplug it first).
3) Now move the hold button to the right and then hold down the center (round) button and then the power button.
4) Once your sansa is on, you can stop pressing the other buttons.
5) Now plug in your sansa.
6) Once this is done, your firmware updater should automatically start. If it doesn't, go to C:\programfiles\sandisk\.... and open it.
7) Select the most recent firmware and download it (it should automatically install).
8) Once this is done, disconnect your mp3 player (your firmware will then update).
9) Turn your mp3 player off.
10) Turn your mp3 player on.
11) go to Settings, USB Settings, and select MSC.
12) plug your MP3 player back into your computer and it should now recognize it.
Jan 09, 2008 | SanDisk Sansa e260 MP3 Player
Follow these steps:
CLICK Here to Download : Firmware Update
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Jan 04, 2008 | Samsung YP-U2X Digital Media Player
Helpppppppp. my zen v plus 2 gb
ZenV Freezes
Have you tried updating the firmware of your Zen V Plus? I've had mine for almost an year and haven't had these issues -- I updated the firmware as soon as I unpacked it.
Before returning the player, try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
Oct 17, 2007 | Creative Labs ZEN V Plus MP3 Player
If your PC still recognizes the player, you can try to drop the firmware update onto the players mass storage area. Once you disconnect the player from the USB cable, the player should begin to update the firmware.
If this doesn't work, let me know. I can look into an alternative method for fixing your player.
Sep 19, 2007 | Insignia NS-DA2G MP3 Player
iRiver T30 MP3 Player Logo
63 people viewed this question
Top iRiver MP3 & Digital Media Players Experts
Steven Wander
Steven Wander
Are you an iRiver MP3 and Digital Media Player Expert? Answer questions, earn points and help others
