Question about Dell Computers & Internet
My Voyager modem will not recognise AOL server.
Always get error 47-ac-3101 when signing on. Igather Voyager 190 needs no drivers. How do I get it to recognise AOL server? It stops on trying to find TCP/IP. I am trying ti get an 87 year old onto AOL 9.0 VR.
    Scholar:
  • 66 Answers
***** http://www.the-scream.co.uk/forums/t23404.html ****** Well Dahlin' , you got questions. Check out the forum I found .. the folks are a hoot. I got a kick out of it none the less. Now back to you, I think the answer lies toward the end of the page there's two different answers that should work. If not a couple of other stuff to try. Good luck. Hope it helps, if it does please rate me. thanks-jmattes
Posted on Sep 26, 2009
Installing BT Voyager 105 on XP Pro PC shows newdev.dll error
I recently had this problem after buying a voyager 210 modem/router to replace the voyager 105 (in my case supplied for AOL broadband)
I tried to uninstall the voyager 105 and encountered exactly this problem - newdev.dll missing, Admin privileges required
After alot of Internet searching I found no answers. But in desperation tried this and it worked. I am by no means any computer expert so don’t blame me if this does not work for you, or damages your machine.
To install my 210 modem I was following instructions found here -http://www.sohodata.co.uk/soho.htm But first I had to get rid of the 210
Here is what I did, exactly as I did it (some of it is probably unnecessary) Further below is a condensed version I expect would work.
1) Firstly I restarted in safe mode by pressing F8 in start-up ( I was doing this because i had remembered an administrator profile and considered attempting to uninstall from there.)
2) I logged on as the administrator.
3) Attempted to uninstall the voyager 105 via control panel and via the uninstall icon in the programme folder. - Both Failed with the above-mentioned problem.
4) I navigated to programme files. (Start> My computer> C drive> Programme files)
5) There I highlighted the folders "British Telecom”, "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", "Voyager Test". I cut these folders wholesale and pasted them to my USB pen/stick (incase I needed to put them back)
6) I then ran disk cleanup (Start> All Programmes> Accessories> System Tools.)
7) Then I turned off my computer and unplugged the USB pen/stick and the USB and DSL cables from the back of the Voyager 105.
8)I turned the computer back on (starting up normally), logged on with my normal username which has admin privileges. Ran the driver install for my new router (previously downloaded from BT at –(http://www.btopenworld.com/broadband/adhoc_pages/driver_homepage.html#yahoodrivers) It stated that a BT driver was already installed.
9) Navigated to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall …. AND IT DID IT! No error, or messages about newdev.dll or privileges.
10) This left me free to install my new driver and go through its install process ending in plugging the USB into the back of the modem and having internet again.
Here is what I expect would work
1) Turn on and log on to any account with admin privileges.
2) Navigate to programme files. (Start> My computer> C drive> Programme files).
3) Select and delete (or to be safe, cut and paste to a removable drive) the folders "British Telecom", "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", and "Voyager Test".
4) Remove removable drive and run disk clean up (Start> All Programmes> Accessories> System Tools).
5) Then I turned off my computer and unplugged existing modem.
6) Turn on computer log back onto account with admin privileges. Navigate to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall.
7) Install desired drivers/modem.
If you find this works for you too and have asked this question elsewhere, please copy this solution so others can solve this problem too
Jul 11, 2009 | Computers & Internet
Newdev.dll error and asking for admin rights on bt modem 105
If you have IE-8 installed, then uninstall it and it will start working.
You can uninstall IE-8 using this command in the run dialog box:
"C:\WINDOWS\ie8\spuninst\spuninst.exe
Regards,
Ashish
Jun 20, 2009 | Computers & Internet
PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
Goto the command prompt bar in the start menu type ' cmd ' then click o.k . A black dos screen will appear type in ' ipconfig/all ' and it will the the two servers you need under dns servers but if your doing a wired connection to your ps3 then you need to manually configure your dns on the custom method of setting up your internet connection on your ps3 as if this is auto config that will give you a dns error. Hope that helps ,I can go into more detail and guide you through it if need to .
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
Sync to computer problems. can't install lgusbmodem.inf file.
If you're using Wwindows, go to your control panel then programs and features, LG USB Modem Driver (if it's there) and uninstall it. If it isn't there, go to your Windows explorer and perform a search and look for the lgusbmodem.inf and delete it from the computer once you find it. Reboot. Download the LG USB Modem Driver from here: http://www.lgmobilephones.com/phone.aspx?id=9416
and install it. If you get the same problem then it is an issue with your Windows installation and not your driver.
Apr 12, 2009 | LG VOYAGER VX10000 Cellular Phone
Nearly every time I try to log-on to AOL I have to press the button on the back of my BT 190 Voyager ADSL Modem and take the power button out,then re-plug it before I get the modem to work. Do I need a new...
TRY CONTACTING THE MANUFACTURER FOR A FIRMWARE UPDATE FIRST JUST GO TO WEBSITE AND ENTER MAKE AND MODEL.ALSO CHECK WITH AOL MAYBE A COMPATIBILITY PROBLEM OR AOL UPDATE MAY HELP.HAVE A GREAT DAY.RICHARDM69
Dec 01, 2008 | Computers & Internet
Lost internet connection. I use BT Voyager 190 ADSL modem on AOL with WIndows Vista. Power and Thernet indicator lights are on solid, but DSL and Internet indicators are off.
Sounds like there is a issue with your phone line. The DSL indicator is the phone line. Check to see if you have a dial tone or if a message is on the phone you haven't listen too, if you have message service. Try unplugging all phone connections as and replug them in again. You also might need a filter for your DSL to phone line. Also if you have an alarm that is monitoring your system, you need to by pass alarm and use a filter.
Aug 01, 2008 | Computers & Internet
Connect OK to Broadband through speedtouch modem from 0151 625 9611 but cannot sign in to email despite having done so for several years. Get message server cannot be found when I am actually connected to...
well...this is a settings issue for smtp and pop servers..if you're on the same DSL or cable service, than those should be identical..just ckeck em to make sure..and the port assignments sometimes need to be different for different modems..check with your ISP and modem maker for this information.
Mar 29, 2008 | Computers & Internet
Speedtouch 576
Have you tried to reset the device using a pin or paperclip, this should restore the device to factory settings and allow your new internet service provider help you with the setup to connect to thier service.
May 12, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Computers & Internet Logo
118 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
