My epson stylus dx5000 has all of a sudden told me that my magenta cartridge is not compatible. how do i fix this?
tom19511
  • 1601 Answers
SOURCE: Epson R260 ink cartridge problem (yes, with the genuine Epson ink)
Try this:
http://er.epson.com:8001/start
Posted on Feb 20, 2008
BinaryCode
  • 54 Answers
SOURCE: Epson Stylus R230 Light Magenta Not working
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
Posted on Jun 12, 2008
SOURCE: epson stylus dx5000 will not
Yes, there is an internal fuse. I have a DX5000 as well which woould not turn on so I ripped it apart to check for an internal fuse as all other fuses, cables etc were fine.
I have to say it is a bummer to get to the fuse in the DX5000. You have to take out each and every part of the assembly before you can reach a fuse on the Circuit board attached to the main input.
It is a T1.25 Amp 250V ceramic fuse which I could not get hold of therefore decided to ditch the printer.
I would say it is not worth the effort, just get a new printer. Look out for deals... I got the Epson Stylus SX200 on a half price deal for just £39.99. Its better and faster then the DX2000 and this time I checked the power input. It is easy to open and access the main input circuit from the back in this one.
NOTE: If you do happen to go for ripping the thing apart then please do not touch the power circuit board with you hands even if the printer is totally disconnected as it has a capacitor on it which will discharge and give you a little shock if you happen to touch it. Good luck.
Posted on Nov 17, 2008
  • 60 Answers
SOURCE: Have an Epson Stylus DX5000
For starters, don't run any more head cleans - too many can cause problems as well as waste lots of ink. Get some Windex (glass cleaner) or if not sold in your area, get a 5% solution iof Ammonia (sold in many countries as latest Cillit Bang - also, like here is Spain, as Viakal) Get the printhead (containing the cartridges) into the Change Cartridge position. Then remove power supply - meaning remove lead or unplug - DO NOT simply switch printer off. Make a two or 4 layer (of linen - like sheeting) pad, about 4" long and around 2" wide after folding. Soak with the Ammonia solution. Slide under the printhead. Reason for removing power supply is when that is done, you can slide head side to side easily. Leave pad under the printhead for at least an hour. Remove the pad. Reconnect the power and switch on. Printer will now perform a clean and should set up ready to print as normal.. Try a nozzle check - you go into Control Panel on computer, double-click on the Printer icon, then select printer, right click and select properties. Check through settings tabbed pages until you find Print Test Page first and try that. Otherwise, go to the settings page and find the Maintenance Tabbed page, where you can select the Head Cleaning and Nozzle Check facilities. Hope full the nozzle check will show a full printout. If unlucky, just repeat the pad routine - and perhaps leave overnight.
Posted on Jun 05, 2009
pineworks
  • 4041 Answers
SOURCE: My Epson DX8450 won't recognise the magenta cartridge.
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on May 07, 2010
Dose the printer epson stylus NX125\127 comes with a USB wire?
Yes
http://www.epson.com.au/products/multifunctional/stylusnx125_specs.asp
but you can buy one yourself for less than $5.
Jul 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
BOUGHT NEW CARTRIGE FOR MY NX 415 AND THEY AREN;T REGOGNIZED!
If the cartridge is not the same code as the previous used by the printer, then it will not be compatible. Your printer has been replaced by Epson Stylus NX415 All-in-One
  • One 69 Black Ink cartridge (T069120)
  • One 69 Cyan Ink cartridge (T069220)
  • One 69 Magenta Ink cartridge (T069320)
  • One 69 Yellow Ink cartridge (T069420)
  • Therefore, ensure that the catridge follows the above code (69).
    Best regards.
    Jun 10, 2011 | Epson Stylus NX400 InkJet Printer
    Your explanation does not seem feasible.. Without any problem I have been using Epson Compatible cartridges for about one year, in the same printer (Epson Stylus SX215). Why should exactly the same type...
    Maybe there are corrupted file in the installed software from your driver so your PC can't recognize the cartridge. Try to re-install printer driver with the cartridge placed inside the printer.
    Hope this help.
    Feb 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
    Type of catridge epson stylus R390 uses can't find
    You can see the reference on the cartridge itself.
    Take it with you when you buy new ones.
    Jul 29, 2009 | Epson Stylus Photo R390 InkJet Printer
    Black and magenta ink cartridges not working on RX425 printer
    Hello, Just a checklist: have you tried to reinstall the cartridges? are the cartridges empty? are the cartdridges compatible (you'll see this on the box)? Hope this helps
    Jun 10, 2009 | Epson Stylus RX425 Multifunction...
    Need instructions for epson stylus dx5050
    Here is guide for CX5000, that is same model as DX5000
    User's Guide
    Below you also find assembly instructions:
    EPSON STYLUS CX5000 / DX5000 / DX5050
    Jan 30, 2009 | Epson Stylus DX5050 All-In-One InkJet...
    35 people viewed this question
    k24674
    jasbo
    jasbo
