Question about Ovens
My fan oven keeps blowing he elctrics in fuse box topoven fine , could it be fan element
    President:
  • Ovens Master
  • 1,922 Answers
Very likely,the element has touched the surrounding case
Posted on Sep 26, 2009
Testimonial: "helpful but not correct as when oven on low dosent blowelectrics,do you know if the element itself is faulty or could it be something else"
My electrolux EOD5330 fan oven tripped a fuse. ow it won't heat. The fan still works
Most likely problem is the the oven element short circuited which caused the fuse to blow. When power is restored everything generally works except for the element. If you check the element you may find a blow hole in it.
Feb 10, 2011 | Electrolux EOD5330 Ultrafan Electric...
My omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Mar 18, 2010 | Ovens
Switch oven on within 3 mintues the fuses blow main fuse box
I suspect the fan oven element has failed, this is located at the rear of the inner oven compartment behind a removeable cover
It is probably breaking down as the element gets hotter.
Feb 28, 2010 | Neff B1421 Electric Single Oven
Problem with electric oven
Either your fuse holder/breaker has a bad connection and has a voltage drop tripping your power  or  your heating element is shorting to it's outer jacket which is grounded.  Check your heating elements carefully for wear and disconnect that element and see if it trips still.
Nov 09, 2009 | Ovens
Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1432 Single circotherm plus Electric...
3rd blown element
no connection between lights on fan. problem is that bulbs these days are poor quality (but cheap)
it is common for these circular elements to go. usually last about 2 years. worth checking tho that fan is turning at right speed
Jun 21, 2008 | Neff U1721 Double circotherm Electric Oven
Hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
Jun 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint dy46 x oven
Usually with ovens not heating up the element has gone and needs replacing. A few checks to do before going to the expense and trouble of replacing are to check the House Power Box Fuses to make sure none a blown - especially look for the one relating to the Oven or Range. If blown replace the fuse wire. If it blows again you have a problem with the power point or appliance. Does the Oven Fan work? If so chances are the oven is getting power as is the element and your house electrical lines to the Oven are fine and the element needs replacing. Not knowing the particular Brand you have amkes it difficult say how to remove the element. Some elements are accessible from inside the oven - others you have to remove the oven and get access from behind by removing a panel. Whatever you do if you do decide to remove the element MAKE SURE you TURN OFF THE POWER to the Oven. Hope this helps.
Regards
Bryan
Feb 22, 2008 | Hotpoint DY46 Style Line Stainless Steel...
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Broken cooking appliance :( please help
if the fan is spinning then it sounds as though the element has gone. has your fuse box recently tripped? it may have been the blowing element.
Jun 10, 2007 | Belling XOU252 Electric Single Oven
Ovens Logo
135 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
