Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Dyson elbow tube clogged
I have a dyson animal and i have a stick stuck in the elbow tube. i took off the piece on the side of the vacuum but the stick is in the elbow at the end of the hose and i cannot figure out how to get that part seperated to pull the darn stick out.
  • 27 Answers
Turn the vac upside down then stretch out the hose the stick will eventually fall out
Posted on Oct 03, 2009
I have the dyson animal. There is something stuck in the wand tube and everyting is getting caught on it. There is very little suction from the wand. How do I get the wand apart or somehow get the object...
Yes, things stuck in vacuum hoses are not always as easy to remove as one might think. Trying to push it out with something can be counter-productive, and only get the thing stuck tighter! If you have a second vacuum, you can try sucking it out the way it came in (and risk getting it stuck in the other machine. Or you can try pulling it out, using a wooden stick with a small hook screwed in the end. If you try a piece of bent wire, you must be careful not to perforate the hose. Usually just requires a bit of ingenuity.
Jan 16, 2010 | Vacuums
How to reassemble vacuum elbow tube with plastic insert?
If the plastic insert has come off then that is not normal. It should be all one piece to the hose. You might have a hose problem that needs replacing.
Nov 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Suction from hose isnt strong enough. Vacuum
There is probably a clog on the U channel (little Gray tube that attaches to the Vac tubing). Pull it loose and look in side all the tubing.
Nov 16, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
No more suction on hose attachment
have you cleaned the foam filter? there should also be a u shaped piece of tubing that connects the attachments to the rest of the machine, sometimes it gets clogged ( quite often, i repair on average 3 dysons a week ) also people tend to loose the tube as well.
Jul 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
No hose suction
Clean your round filter and make sure there is nothing in the elbow tube in the bottom/back of the vacuum.
Jan 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Changing the main hose on a Dyson DC15 Animal
Hi Bob.
If you look carefully where hose & elbow jount enter machine you will see a slot.
Rotate elbow so that lug on elbow aligns with slot & pull off.
http://dysonmanuals.llc.nu
Jan 12, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Brushes turn but won't ****
Had the same exact problem (literally the EXACT problem) Take out the elbow tube and make sure it is clear. I found a small little plastic part (very small), but it did not make the turn. When I took the elbow tube off, it feel out. Upon reassembly, everything worked fine again. Seems that if the not the right amount of air flow is on, it stops.
May 29, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson 07 won't stand up
I talked to Dyson support (they are open 6 days a week, try them if you're stuck)
Turn the vacum on it's side. Look on the side that has Bare floor/carpet control. There is a hose with two yellow buttons. Detach the hose. On the square side, look for a black button. Depress the button, then release. On the square side, slide the square up until it locks in place.
Now try to see if it will go upright (it should)
Finally, re-attach the hose.
Apr 18, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
469 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
