Question about HP Compaq WF1907 Monitor
Htldr missing and beeping
When i turn my notebook on i get the msg htldr is missing then i hear a beeping sound that keeps going on and after a whille it turns of what shall i do
    President:
  • 1,462 Answers
CAUSE:
This problem may occur if the MFT root folder is severely fragmented. If the MFT root folder contains many files, the MFT may become so fragmented that an additional allocation index is created. Because files are mapped alphabetically in the allocation indexes, the NTLDR file may be pushed to the second allocation index. When this occurs, you receive the error message that is described in the "Symptoms" section.
Typically, files are not written to the root folder. This condition may occur if a program regularly creates and removes temporary files in the root folder, or if many files are copied to the root folder by mistake.
SOLUTION:
To resolve this problem, follow these steps:
  1. Contact Microsoft Customer Support Services to obtain the Bcupdate2.exe utility. For more information about how to contact Microsoft Customer Support Services, visit the following Microsoft Web site: http://support.microsoft.com/contactus/?ws=support (http://support.microsoft.com/contactus/?ws=support)
  2. Insert the Windows XP cd and boot from the Windows XP cd, Press R option to repair and you get command prompt
  3. Run the following command at the command prompt to extract the Bcupdate2.exe utility from the software update:
    Expand drive_letter:\bcupdate2.ex_ drive_letter:\bcupdate2.exe
  4. Run the following command at the command prompt to update the boot code of the NTFS boot sector:
    Bcupdate2.exe C: /F
    Note Other command-line parameters are supported: /q - Quiet mode (must include /y)
    /y - Don't confirm
    /f - Force update of in use volume
    /t - Only test for old boot code
  5. Press Y if you are prompted to update the volume. You receive the following message after you successfully run this utility: The boot code was updated successfully
If you are novoice user and if you feel these step as difficult, simply reinstall the windows
Please rate this solution
RNJ VINODKUMAR
Posted on Sep 26, 2009
    President:
  • 942 Answers
In terms of ntldr the operating system is corrupted so you need to install and get a full copy of windows. In the beeping problem it came from the memory so check the memory stick if it is correctly installed.
Regards
PCmania
All sound geting a long beep
Hearing a 'beep' is usually to warn you there is a fault. I do not know a single long beep as a code for your Notebook. Turn it on and do not touch anything, and see if there are any short beeps and/or other long beeps, and let us know
Quite often it is a fan problem, can you hear your fan running and does it sound normal?
Feb 10, 2014 | IBM ThinkPad A31 Notebook
Bizhub beeps constantly
Go back into the same screen. You must have missed some sound settings. They can all be turned off in this area. No other way to do it.
Jan 29, 2014 | Konica Minolta bizhub Office Equipment &...
Beeps while driving
Check your speed alarm in your computer. It maybe setup to alarm when going over that speed and it will only do it once during that trip if I remember correctly.
Mar 22, 2010 | 2004 BMW 5 Series
Monitor wont work when i turn laptop on i hear 1 long beep then 2 short beeps
then have your memory or vga card check if you hear this beep sounds it is a memory or vga hardware failure, take your notebook to a certified laptop tech, if you want to troubleshoot but unsure on what to do, better have it check by an expert to avoid any more damages to your unit
Nov 24, 2009 | HP Pavilion dv6000z Notebook
When I turn on my ps3 system on, there is no signal on my T.V.
With the system off, hold down the power button on your PS3 for 10 seconds. This should set everything back to factory defaults. If that doesn't work, try holding it down until you hear the beep that sounds when the system turns on. Keep it held until you hear 2 more beeps, and release it instantly. If it doesn't work after that, then its going to be a problem with either the power supply, meaning that its missing some off the voltages which powers on the system properly or the main board is bad, at that point you would have to call Sony Tech Support.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
Strange beep and keyboard skips or misses strokes
Hi
Go to security center then check for settings. hardware and software is not the issue,. only the settings!
Thanks!
Jun 06, 2009 | HP Pavilion zd8000 Notebook
Voicemail and Txt alert sounds
then you will need to have the firmware reflash or take it to the store and hvae them explain why it is still doing that.....the phone firmware may need fixing.
Sep 10, 2008 | Motorola Mobility RAZR V3
I get a loud beep on my laptop but cant hear anything else
There is a beep system in all PC's
One quick been means the computer is OK when starting.
one long continuous beep is defined as :
' Power Supply or System Board / Keyboard stuck '
Note: Alternately it could be a Memory module
However it's more likely that it's the above
If you check those two things, you are likely to find the culprit.
If not, you need to post your BIOS and
Feb 20, 2008 | Dell Inspiron 2200 Notebook
Aspire 5100 problem
You can disable this msg through msconfig or you can restore the os through system tools, if msg is again comming then try to edit the regestry & delete the entry(you can try all this).
Feb 13, 2008 | Acer Aspire 5100 Notebook
HP Compaq WF1907 Monitor Logo
221 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
