Question about Toshiba P000392200 - Satellite A40, A45 Series 2.4GHz Intel Pentium 4 Processor (P000392200CPU) PC Notebook
Battery not charging
Satelite pro a60en battery will not charge above 1%
  • patrickligg Sep 26, 2009
    this a new battery
  • Toshiba Master
  • 32,281 Answers
Rechargeable batteies have a finite number of charge and discharge cycles. Over the life of the battery (over 2 or more years old) it will degrade and its charge capacity will be reduced as the battery ages and eventually will not charge at all.
The only option is to replace the battery.
Posted on Sep 26, 2009
  • Chris Hingee
    Chris Hingee Sep 27, 2009
    A new battery that has been sitting on a shelf needs to be charged and discharged several times before it can reach its full operating capacity.
    If the battery does not appear to charge, there are only two possibilities, either the new battery is faulty or the charge circuitry in the laptop is faulty.
    Try to get the battery charged in another Toshiba laptop or get the supplier to charge the battery for you.
Chaging batter
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
I just bought a new laptop battery for my toshiba satelite A105, but the problem is the changing the battery, when the battery is low then i plug in the AC adapter the laptop keeps using the battery...
Make sure that the replacement battery is registering as a proper replacement and not a knock-off. This will sometimes cause them to act funny.
Check the power settings under Control Panel. It's a long shot, but there might be a weird setting in there.
Nov 10, 2012 | Toshiba Satelite A105-S4102 Notebook
My poulan pro lawn tractor won't start. when i turn the key it click's 1 time can you help ?
Have you checked the battery terminal connections? Is the battery charged fully? Are you sitting on the seat when you try to crank the mower? Could be any of the above but most likely battery connection or the battery is discharged or old.
Aug 20, 2012 | Poulan Pro Lawn Tractor 2006 and Newer...
Toshiba satelite pro L300
Batteries only have a useful life then they have to be replaced. If it is not charging then it is bad. Otherwise if your power cord was bad, it would not charge the battery and then you wouldn't be able to power on the laptop.
Apr 23, 2012 | Computers & Internet
My satellite pro A60en do not want start. its just dead
Please elaborate your problem. Is it even showing any led light? Check your battery if its charged and also whether the power adapters been working fine.
Jul 18, 2011 | Computers & Internet
My laptop won't charge
What do u mean by "adjust the cord" ? If u have to adjust by twisting the jack in the power input port then it is neither the fault of the cord nor the of the battery but may be the fault of the power input port.
Go to Toshiba service center and they will solv the prob.
May 23, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
I have a Toshiba 4200 series and would like to know what each of the five light are for.
From the left,
1, Mains power connected
2, On (glows green when system is on)
3, Battery orange when charging green when fully charged
4, Hard Drive green when accessing
5, Floppy or CD drive activity
Light above keyboard<
1, caps lock
2, arrow mode
3, num lock
May 11, 2010 | Toshiba Satellite Pro 4270CDS PC Notebook
Toshiba satelite a215-s4747 battery will not charge /replaced battery and still will not charge/ updated bios and still will not charge ?
check the pin on the power cord . try with a different ac adapter . if it is still not chargin maybe the internal pin may be damaged.
Oct 20, 2009 | Computers & Internet
Hey
the battery is getting poked its not charging buy a new one
Jan 20, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba P000392200 - Satellite A40, A45 Series 2.4GHz Intel Pentium 4 Processor (P000392200CPU) PC Notebook Logo
157 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
