I need to clean the heads of an hp 3in1 printer but i have no disc or cable to connect it to a computer
  • Alun Cox May 11, 2010
    Model no pleas
  • 615 Answers
If you do not have, the cable to connect to your PC then how is going to use it. you need to get the cable and that is very easy look at e-bay you may be lucky to save some money and after you get the cable you can download the software and drivers to your PC and conduct the self-cleaning. let me know Again thank you for giving me this opportunity to assist you Please see that grant me your approvals by rating my service and I hope that I can serve you again the future.
Posted on Sep 26, 2009
My Epson wf-2540 printer won't print black I have done head cleanings and have new ink in it as well. What can I do to fix the problem?
Run a print head nozzle check to see if any of the nozzles are clogged. Then clean the print head, if necessary.
Printing problems can be caused by cables that aren't connected properly, corrupt drivers, incompatible drivers, printer settings, missing updates, and problems with your printer. Might be best to start by insuring you have the latest printer drivers? Lastly, you might give the printer manufacturer a tech call. Good luck, Pete
Jan 17, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
Wont print light flashing
Dis connect power socket, detach usb cable wait few minutes, connect power switch on printer, check for ready mode, still blinking, remove color/mono cartridges one by one verify,blink gone replace defective cartridge, if problem persists clean encoder strip,disc encoder & paper path sensor..Encoder:12_24_2011_4_31_37_pm.gifDisc encoder
12_24_2011_4_32_38_pm.jpgPaper sensor location,sensor visible from backside
Dec 24, 2011 | HP Deskjet D1420 InkJet Photo Printer
My printer is a HP- 6210, Message: "remove and
Hello Cliff, welcome to FixYa.
Hard Reset the printer by doing the following:
  • Remove all the ink cartridges.
  • While the printer in ON, unplugged the power cable from the power source.
  • Disconnect the USB cable at the back of the printer (if your printer is connected through a USB cable)
  • Restart your computer.
  • Connect back the USB cable.
  • Plug the power cable to its power source.
  • Turn ON the printer if it does not turn ON automatically.
  • Install the ink cartridges.
  • If the printer prompts for an print head alignment, please do so.
If the problem persists, replace the ink cartridge. The cartridge might be defective since you already have tried to clean the contacts.
Keep me posted.
Jas
Sep 28, 2011 | HP Photosmart 2610 All-In-One InkJet...
I have a hp deskjet f2480 that wont print anything from my computer
Make sure the printer cable is connected firmly.
Make sure the printer driver is installed correctly.
You may have blocked inkjet nozzels in the print head.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 15, 2011 | HP Officejet J5780 All-In-One InkJet...
I want to connect my new computer to my printer
You mean connect printer to computer .
Before connecting the cables , insert the install disc in the computer drive and follow instructions . When installation os software/driver is completed , connect the USB cable to computer and printer and power cord from printer to AC plot . Press the power button and wait for Windows to confirm installation is successfull .
You can now use yoiur printer .
Best regards ,
fanaudi .
Aug 13, 2011 | HP Deskjet 2460 Printer
HP C8189 All in one printer....Error Oxc 19a0005
Please remove all cartridges. Using a moist cloth clean the golden contacts on cartridge as well as printer. Use a moist cloth to clean the nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Then plug in the cartridges.
Now see if its working fine. Let me know.
Dec 02, 2010 | HP Photosmart C8180 InkJet Printer
We have HP Designjet 110plus. Our magenta is flashing saying that it is out of ink, however it wasn't. We replaced it with a new cartridge, and it still reads empty. Please help!
Turn off the printer, disconnect and remove everything like power cable, usb cable, cartridges etc.. Connect your power chord and power on, leave it for few minutes (clean the cartridge interfaces not the head, and the corresponding interfaces on the printer). Again shut down the printer using the power button. Reconnect/reinsert everything, and again power on the printer before you connect the Usb to the computer. Now check if it helps or not. This will clear any static memory/voltage. Good luck Thanks for using FixYa.
Jun 01, 2010 | HP Designjet 110plus nr InkJet Printer
How can I clean my printer heads on my HP Officejet 4580?
that utility is in the properties of the proper printer.
Mar 26, 2009 | HP OfficeJet J4580 All-In-One Laser...
New Dell Inspiron connected to HP 820Cse printer. Won't print.
I've not worked with one of these cables before, but here's what I would do: Right-click on the printer icon and go to properties. You'll be looking for the tab that says "ports." Open that tab and see what port the computer thinks it's using for the printer. Chances it says it's using a parallel port, but it is in fact, using a USB port. I can't tell you which to choose without looking at what you see, but I think you might find one that makes reference to a USB port with a parallel connection of some type. Try clicking on that and see if your situation improves.
Feb 24, 2009 | HP DeskJet 820Cse Printer
HOW DO I CLEAN MY PRINTER CARTRIDGES/HEADS?
For using the HP Deskjet 5000 series Printer Assistant:
  1. Double-click the 5000 series printer assistant icon on the Desktop of the computer.
  2. Click Utilities .
  3. Click Printer Maintenance .
  4. Click Clean Cartridges .
  5. Follow the on-screen instructions.
read info on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09339&cc=us&lc=en&dlc=en&product=71896
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 15, 2008 | HP DeskJet 5550 InkJet Printer
56 people viewed this question
jasbo
jasbo
