Question about Cyberhome DVR 1600 DVD Recorder
Wont switch on fuse ok - Cyberhome DVR 1600 DVD Recorder
  • level7_500 Sep 26, 2009
    yes its ok
  • paul hughes May 11, 2010
    have you tired the fuse inside the unit on power board
  • 2,385 Answers
Power supply gone, needs technically handle. contact authorized service center or qualified technicain to fix it.
Posted on Sep 26, 2009
Testimonial: "many thanks"
Blinkers wont blink change the relay fuses ok
What about the turn signal switch on the steering column? Did you use a testlight and check voltage at the turn signal fuse? Goes hot when you turn on the key.
A lot of times, it's the turn switch or wiring in the steering column, but, It don't hurt to check the basics.
Feb 20, 2015 | 1999 Oldsmobile 88
Went bang tripped fuse now wont turn on
Did you flip the switch in the switch box back on?
Dec 26, 2013 | Kitchen Ranges
2002 thunderbird window won't go up or down replace swith still wont work fuse are ok does the switch get power
The master switch connector does have circuits that have power on them. The Master switch is not directly connected to the window motors. The switch sends a signal to the Front Electronic Module and the module controls operation of the motor on the driver side. The passenger door window motor is controlled by a different module
Nov 28, 2012 | 2002 Ford Thunderbird
Cigarette lighter wont work on my 1998 acura 3.2 tl. Dont see a fuse under the hood
The cigarette lighter works only with the ignition switch in the ACC or ON position. In the under-dash fuse/relay box, you will find the cigarette lighter relay and the 10A RADIO fuse 11. If the fuse is OK, check 15A INTERIOR LIGHT fuse 57 in the underhood fuse/relay box. If OK, check 50A IG SW fuse 36
Oct 09, 2012 | 1998 Acura TL
Our headlights wont turn on. Is there some way we can check this problem, thanks D.Bonchek
check to see if power is at headlamps with switch on. if not check the fuses, there should be a left headlamp fuse, as well as a right headlight fuse.in underhood fuse box. if the fuses are ok. then it may be in the wiring or the switch. check the switch for power when turned on.
Jun 01, 2011 | 1999 Chevrolet Malibu
I own a 2001 dodge dakota 4x4, my brake lights wont work, I have park lights, turn signals, back up lights, even 4 way flashers, I replaced the brake unit on the brake pedal, and checked all fuses, they...
When you say you checked the fuse, was this just a visual check....or did you try replacing the fuse the a new one? Sometimes a visual check doesn't show minute breaks in the fuse wire, which gives a false appearance that the fuse is fine.
When the fuse is ok, this problem normally relates to the brake switch (mounted to the brake pedal). When this switch is replaced, you should always use a multimeter and check the switch is operating correctly when touching the brake pedal.
If the switch is ok, then suspect a faulty relay (if applicable to the Dakota).
Cheers,
May 14, 2011 | Dodge Dakota Cars & Trucks
2001 blazer wont start . gas gauge quit working ,fuel pump wont work will work suppling power to port in fuse panel. ecm fuse ok,relay ok
Sounds like the ignition switch has gone bad and will need to be replaced. Turn the ignition switch to the on position again and check to see if there is power to other items like the transmission and accessories. If there are a few items that are not working, good chance that the ignition switch has gone bad and is there any security light on the dash flashing???
Thank you for using fixya and keep us posted.
Nov 17, 2010 | 2001 Chevrolet Blazer
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
S80 backup light wont work
There are only 2 things to check other than the bulbs, 1st the back up lite fuse, and the 2nd the back up light switch on the trans, if the fuse is ok replace the backup light switch.
Nov 19, 2008 | 1991 Volvo 240
Cyberhome DVR 1600 DVD Recorder Logo
178 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
