Video driver not working - Computers & Internet
  • 525 Answers
First , put the power on, after it will start, press F8 , you will go in safe mode. Then uninstall video hardware, by opening the computer management. after , restart the computer, window will reinstall again.
Good luck
Thank you Francois
Posted on Sep 26, 2009
My VGA has been corrupted. How can I fix it?
Hi , I suggest to check for any thermal issues including condition of the video card fan / heat sinks ie dust ,
If supported you can run a LINUX disk like Ubuntu in live / try mode
If video works ok , then most likely a Windows environment incl hardware conflict or virus / driver corruption issue ,
but if not then most likely a video card hardware issue like bad card cooling fan or excessive dust - thermal shedding issue or card bios/chipset fault
If a likely software issue then uninstall and then reinstall the video card
Consult ASUS or Nvidia support
The procedure is something like this
Onboard video support ?
yes
uninstall the video card driver and any video vendor configuration applets
Uninstall video card in device manager if still present.
Shut down and remove mains power cable
remove the hardware video card ,
(using anti static electricity procedures)
Attach onboard video to display
Power up and enter and configure BIOS setup if required, ie 1st seek onboard video
Bootup to Windows
Install the onboard video device
using Windows plug&play default driver executed during booting
Restart
Confirm working ok
Update the chipset driver (inf) if applicable,
restart
Shutdown
Reinstall the hardware video card
Attach to display
Reconfig BIOS setup if required
Start to install default driver
Install video driver / update from card default using a known good driver whose setup file has been previously downloaded
restart and test
Hope this helps
Dec 06, 2013 | ASUS GeForce Computers & Internet
Tip
Hi, thanks for the great info. It worked but not right at first. I had already...
Ulead Video Studio SE DVD how to run on Windows7 64 bit systems by Not you. Drivers updated now has drivers for XP Vista and Windows 7 7/16/2010 Getting started,you will need another program its called USB-AVCPTSetup_For_Win7 you can get it here... download links are at the bottom of page.Do not install at this point save to your desk top! Ok your ready Do not plug in your Easy cap usb drive. 1. Put the EasyCap disk into your CD Rom When auto play starts click Run HAutorun.exe a window will open DO NOT INSTALL THE DRIVER !!!! 2. click Install Video Studio,complete the install adding your code with no driver reboot when asked. after reboot remove the disk you will not need this anymore. 3.DO NOT INSTALL THE EASYCAP USB DRIVE YET. 4. Install the software you saved to the desk top (USB-AVCPTSetup_For_win7) reboot your system. 5. Plug in the EasyCap USB stick and wate till the driver installs this will be done auto,in a few seconds. 6. Sorry to say but you need to reboot now. leave the USB drive in its port. You are now installed but your cam will only show a black screen at this point,its ok we are now going to resolve that. Start the Ulead Video Studio. During the start up you'll have the choice of VideoStudio Editor or Movie Wizard click the 16:9 ckeck box at the bottom then click VideoStudio Editor. New window will open click Capture,now look for capture video button on the right side of the black screen,click it Just to the right you will see an Options button click. A drop down will show,look to see if input source is in dark letters,if so open and set source to NTSC/M and composite video is checked. If the input source is greyed out,open Capture properties directly under the input source,a new box will open click properties a new box will open this box will have 3-4 tabs you only need the first tab called Image tab under video sources click ntsc/m and composite video click ok click ok again thats it you should now have video,After any restart you will need to reset ulead up again,you should be good to go...... Hope this helps :-} Here are some pic's to help.Note after the instalation,if you move the Easycap usb drive from the usb port it was installed in and input it into any other port it will not work,the driver will need to be reinstalled!!! 09c750d.pnge0aeff9.png78f955a.png New download links For Windows XP/VISTA/7 32-Bit, please download Windows 7 64-bit This web page I have not goten any link to open but thought I'd add it so you all can see it,if anyone gets it open please post any or all links for us all. Thats all for now I'll upload more as I get them. ps working with a company rep now,update for easycap d60 4 input style,If not getting a picture on input 1 move to 3 for setup and one camera setting.
on Feb 23, 2011 | DekCell EasyCap USB 20 Video Capture...
Bccode 100000ea bcp1 8a8a8c70
This might indicate a hardware problem with the video adapter, or a faulty video driver.
Try reinstalling the video card drivers by doing the following:
1. Download Driver Cleaner Pro or Driver Sweeper (both have free versions; make sure the version will work with your OS) to your desktop screen and install.
2. Download the latest diver(s) for your video card but don't install them.
3. Uninstall your video card drivers and reboot your PC into Safe Mode. Run Driver Cleaner Pro or Driver Sweeper but ONLY for the video card drivers. I had someone use it on their chipset drivers! If it doesn't find any video card drivers that is quite okay.
4. Reboot and install new video card drivers.
Oct 11, 2013 | Alienware PC Systems Area-51 750i PC...
I don't find any video driver to work on Windows XP SP2 or over
Download free software Driver Max from www.drivermax.com will detect all driver updates and any unknown hardware devices and install for you. Free version only lets you do 2 updates per day so choose your video driver first....cheers from Scott
Mar 18, 2010 | Sony VAIO VGN-S360 Notebook
Video driver doesnt work after new WinXP install- system locks up
it will lock up if you not using the correct driver try downloading a driver version that support sp3 go to thier website and browse for a driver the will work with sp3
Nov 22, 2009 | Sony VAIO PCV-W20 PC Desktop
I have a HP Pavilion dv4155cl LapTop, I need the video driver, because it's not working any more.
You can download the latest video driver from the HP WEB site, their support/download page. Make sure you select your model laptop and the Windows version of your video card.
Are you sure that your video driver need reinstalling?
If you are not sure that your LCD screen is working, connect an external monitor to the laptop's video output connector.
Jan 25, 2009 | HP Pavilion dv4155cl (EC321UA) PC Notebook
Error code 075d
1.Uninstall the video driver under ADD and REMOVE programs
2.Download the latest video driver from support.dell.com, use the service tag of the system and look for the correct video driver and reinstall video driver
3.Reboot system
That should work!
Oct 08, 2008 | Computers & Internet
Driver not working with recent OS versions
I dont get it. On win98 the driver works, on xp or later it doesnt? the windows doesnt find the driver that you've downloaded?
Feb 05, 2007 | S3 Trio64+ Graphic Card
Windows 98'
We confirmed the following software and drivers compatibility with Windows 95, 98, and ME. Picture Navigator JLIP Video Capture JLIP Video Producer JLIP Video Player Card Navigator USB Drivers GV-PT2 Printer driver & Capture GV-DT1 Printer driver & Capture Video Navigator None of the above software will be compatible with Windows NT. At this time there are no drivers available to make these software programs compatible with Windows NT. There is an update available for the Picture Navigator software to work with Windows 2000 and XP in the Customer Support area of this site. (When executing the update be sure to have Picture Navigator closed). The following versions of software and drivers will work with Windows XP. Picture Navigator 2.1.5.1 JLIP Video Capture 3.1 JLIP Video Producer 2.0 JLIP Video Player 1.0 Card Navigator 1.0 USB Drivers Video Navigator
Sep 14, 2005 | JVC GR-D70EK Mini DV Digital Camcorder
Windows 98'
Sep 14, 2005 | JVC GC-A33 Digital Camera
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
