Question about LG WM1814CW Front Load Washer
Water will not drain. The hose is not bend. - LG WM1814CW Front Load Washer
    President:
  • 942 Answers
If your washer won't drain, check these:
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
t doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Regards
PCmania
Posted on Sep 26, 2009
Water will not drain through connected drain hose
The problem you're experiencing can be caused bu 2 things: The drain hose is clogged or to long or the inner drain tubing to the hose connection is clogged.
The drain hose clog is is easy to solve. However, the inner tubing clog takes a little more effort.
First turn the unit OFF & unplug it. Disconnect the drain hose. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connector hole and inner tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow.Reconnect the drain hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose end for water flow. be patient as it may take 5 to 10 minutes to start flowing.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helps you to solve the problem. Thanks for choosing FixYa.
Sep 20, 2011 | LG LD50EL Dehumidifier
Tip
My dishwasher will not drain the water.
This can be one of the most common faults with dishwashers i find that i get called out for. Generally there is nothing actually wrong with the mechanics of the unit.
Most dishwashers have a certain time to drain the water away and any restrictions in the waste hose or the drain pump not turning causes the unit to fault.
1. Firstly Check and clean the filter in the base of the unit as this may be blocked.
2. Then check for any kinked hoses from the sink end to behind the unit. Sometimes extension hoses are attached to the existing hose which are not the correct type of hose and this can then sag and then cause a restriction in the hose.
3. Remove the drain hose from the U bend under the sink. Check the drain spigot where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot hole not being drilled out large enough. This then causes a blockage. Or a foreign particle too large to go through the hole gets trapped here. If you find it blocked clear the blockage and open up the hole so there is no shoulder for blockages to start forming again.
4. Also check the non return valve under the filter and make sure the drain pump can turn freely if your model has access to this. You may just have something trapped in the drain pump. Glass or plates are a common thing to break in a dishwasher and get trapped here in the drain pump. The pump then cannot freely turn and drain the water away. Glass is also hard to see with water in the sump so use a torch.
5.Lastly see if you can hear the drain pump switching on when the unit first starts up. This is before the unit fills with water, If it doesn't then the pump may be defective.
Hope this helps.
on Mar 10, 2010 | Dishwashers
Despite having a hose connected to the drain my dehumidifer still drains into the bucket. Is there a setting or a switch that I need to change?
sommrhome - You're having to empty it, because either the drain hose you have connected to the unit is clogged or the drain hole at the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose should not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Remove the hose and check it for clogs. If clear check the drain hose connection, using an 18" long appropriately sized Zip Tie. Carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. Gingerly work past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. The while slowly pulling it out, rotate the Zip Tie. This will dislodge the clog. As you reach the end of the Zip Tie removal, be prepared for some water to follow. CAUTION: BEFORE DOING ANY OF THE ABOVE TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
The above should solve the problem for you. Please let me know. Thanks.
Jun 08, 2011 | Kenmore 54701 Dehumidifier
I own a Whirlpool Dehumidifer Model Number AD 70USS1. I have a drain hose connected to the unit, however, recently the unit's internal collection bucket fills with water to the point that the...
superstee - You're having to empty it because either the drain hose you have connected to the unit is clogged or the drain hole a the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose would not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Jun 08, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a danby ddr7009ree humidifier which I am trying to drain with the hose in the back however water just keeps filling in the front bucket. I have removed the rubber plug from the back of the unit.
The continuous drain hole (where the hose is inserted) is clogged. To remove the clog, you will need an 18" long plastic Zip Tie (or something similar. But NO wire cost hangers) that will fit into the hole.
Insert it slowly and push until you reach a bend in the tubing. You will need to gingerly work it past this bend until the Zip Tie bottoms out or you run out of Zip Tie. Then, while rotating it, pull it out slowly. As you reach the end of the Zip Tie, be prepared for some water to follow. Also make sure that the drain hose, when reinserted is not crimped and the end is lower than the drain hose connection. The unit does not have a pump. It relies on gravity to drain water through the hose.
Hope this helped you to solve the problem. Please let me know. Thanks.
May 26, 2011 | Dehumidifiers
The water fills the bucket and bypasses the hose I have attached wich should just empty the water into a drain.
Paul, there is a clog either in the hose or in the connecter tubing you have the hose connected to. Use an 18" long plastic Zip Tie (or something similar. NO wire cost hangers, though) that will fit into the hole at the hose connection. Carefully insert it into the hole and work in until you reach the bend of the tubing. Here's the tricky part, as you have to work it past this bend. Once you do and the Zip Tie bottoms out or you run out of Zip tie, slowly pull it back out, while rotating it. This will loosen any clogs, so be prepared for water to follow.
Also. keep in mind that the hose should be no longer than 5'. As the dehumidifier relies on gravity to drain the water through the hose.
May 23, 2011 | GE Ader50ln Dehumidifier
Hello, i bought an LG front loader washing machine (WD 11020D)just 2 weeks back. After every 2-3 washes, the drain filter becomes full of water in a way that even water remains in the drum after the...
you may have a kinked drain hose so the water cannot drain out properly. or if you have the drain hose plumbed into your sink u bend the hole in the spigot may not be opened up large enough.
Aug 23, 2010 | LG Washing Machines
Hi, I have the astoria jada ak super automatic. I
The drain **** is either blocked or bend or is making a big bend which is blocking water in it a this making dificult for the drain water to flow. Their is also a smal chance the main drain pipe to be blocked so you can try to put the drain hose inside a bucket to check if the water can run through you drain hose
Feb 06, 2010 | Astoria JADA AK SUPER Espresso Machine
Electrolux dishwasher won't drain. Not a clog in the outlet hose or drain pipe.
The drain hose on a washing machinemag-glass_10x10.gif connects the drain pump to a stand pipe, a U-pipe under the sink, or another place for draining dirty water into the sewer. If your washer won't drain properly, the problem is sometimes an object blocking the drain hose, like a pair of underpants, a child's sock, or pieces of something that broke up in the washer.
  1. Unplug the washer and put the plug on top of the machine to keep it out of any spilled water.
  2. Step 2 Take any wet clothes out of the washer and bail the water out of the drum with the bucket. The washer may be too heavy to move if it's full of water and wet clothing.
  3. Step 3 Pull the washer out from the wall enough for you to get behind it.
  4. Step 4 Remove the plate from the back of the washer by taking out all the screws. Different brands and models of washers vary in how many screws hold on the back plate, and not all models require removing the plate to get to the pump where the hose is attached.
  5. Step 5 Locate the drain hose. Of the three hoses coming out of the back of the washer, the drain hose is the largest in diameter and is attached to a drain pipe instead of a faucet.
  6. Step 6 Check the drain hose for kinks and bends. These are often the cause of a blocked or slow-running drain hose.
  7. Step 7 Remove the drain hose from the washer by detaching it from the drain pump. You will need a screwdriver or a slide-lock wrench to open the clasp that holds the hose to the pump, depending on what type of clasp it is.
  8. Step 8 Keep the bucket nearby to catch any water that comes out of the drain pump when you remove the hose.
  9. Step 9 Remove the other end of the house from the pipe it drains into.
  10. Step 10 Bend the clothes hanger open so you can use it to poke inside the hose. Push or pull out the material that's causing the blockage.
  11. Step 11 Replace the hose and run the washer to check if it's clear.
Nov 13, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
LG WM1814CW Front Load Washer Logo
175 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
