Ap3800c sc990 printing rip data sheets a-z
RICOH AFICIO AP3800C CS 99 CODE HOW CAN I FIX THAT
I am new to this printer myself. but most codes error I see have 3 numbers to it I can only say that the codes I see for this printer with 9 in it are:
SC990 Defective software
SC998 Application start error
Maybe the machine lcd not show all the number on it.
Pineworks.
Jan 05, 2010 | Ricoh Aficio AP3800C Laser Printer
Sc990 on Aficio 1035
Software performance error The software attempted to perform an unexpected operation.
Software defective Internal parameter incorrect
Insufficient working memory When this SC occurs, the file name, address, and data will be stored in NVRAM. This information can be
checked by using SP7-403. Note the above data and the situation in which this SC occurs. Then report the data and conditions to your technical control center.
Ok, that's the "OFFICIAL" meaning, in reality, EVERY TIME I'v had this, it took a PM or at least a Developer change and a good idea to replace the Drum and Drum Cleaning Blade too, Be sure and run the setups too.
Enter the service mode.
Clear modes, 1,0,7 and hold down the Clear/Stop key. Press COPY SP on the display and enter the following info.
SP2001 = 1480V
SP2201 = 600V
SP2801 (after new developer is installed)
SP2805 (after new drum and developer is installed)
SP3001-2 (after cleaning the ID sensor and/or replacing the drum)
SP7804
SP7807
Good luck.
Sep 04, 2009 | Ricoh Aficio 1035 Copier
Wont print 2 colors, only black and white
The print driver might be defaulted to black and white. Change it to color.
May 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Feb 26, 2008 | Ricoh Aficio AP3800C Laser Printer
Error code SC670
Its an over load of information by the file.
here is the actual code: SC670 mistake Engine Response
Jan 25, 2008 | Ricoh Aficio AP3800C Laser Printer
Switch on Error
SC285 Line Position Error
SC388 Data Transmission Time Out (Hard Disk Read)
Development Gamma Error (Cyan)
Nov 27, 2007 | Ricoh Aficio AP3800C Laser Printer
AP3800c ricoh hard drive
The hard drive store some data about your machine but only uses about 200 mb of the 40 gig .you can use the machine for locked , stored , sample , hold prints , it is for mabe if you got 20 users and they dont want to print and everyones doc;s get mixed up , so it holds the job until you go to the rinter and rints it out
hope this helps you
Nov 03, 2007 | Ricoh Aficio AP3800C Laser Printer
67 people viewed this question
k24674
jasbo
jasbo
