Question about Acer Aspire One Netbook 8.9" Notebook
Acer AspireOne D250 tv/out capability?
I was wondering if I could plug an adapter into my VGA port (the only video port on my laptop) the adapter ends in female RCA ports, would I be able to connect RCA cables to the adapter, and display on a television? the graphics card listed by windows is: ''Mobile Intel(R) 945 Express Chipset'' any help would be greatly appreciated!
  • Acer Master
  • 8,404 Answers
This probably will not work. The rca jacks are for a RGB monitor.
If you want to use a monitor, you can. Get a proper VGA cable and remember the drivers will need to ge updated, probably.
Posted on Sep 28, 2009
  • 3,153 Answers
Lots of people are doing this and part depends on what your home theatre has to offer in the way of connections.
For sound most use the LINE OUT on a computer or laptop and connect that to a suitable input on the receiver using a 3.5mm to stereo phono lead.
If you are lucky enough to have an OPTICAL sound out on your computer and one on the home system that would be a better option.
For the video side again it depends on what your computer has to offer
If it has DVI and your TV or home system has DMI then that is the very best option. Remember to lower the resolution on the computer first and to check and of your graphics card options for dual display. A DVI to HDMI lead is needed for that
NVIDIA graphics cards seem to work best in this area.
If you have a VGA connector on your TV that is another great option and you would only need a VGA lead.
Some cards and laptops have S-VIDEO out. Lots of TV's and home systems have these and the display is quite reasonable. If using S-video connections use a GOOD quality cable.
Some people can only obtain a black and white picture so check your graphics card did not come with any special adaptor.
Another method is composite video Even that is not always 100%
Some laptops need a special S-video adaptor which is just a short little cable to properly enable the S-video and convert S-video to composite. That is probably the worst way to do it.
Using a VGA to component lead is also an option but results vary wildly from no picture to quite good. A lot depends on the quality of the lead once again.
I use the optical sound and DMI lead to power a 50" Sony with great sound and picture.
Posted on Oct 04, 2009
  • 34 Answers
Ok thanks for ur comment, I think its gonna work, u have use a cable vga , which u knews, it will work
VGA-HDMI connection fail on Acer projector using adapter
You don't say whether or not the "adapter" is simply a gender-changer, or if it actually converts the digital signal from the HDMI port to an analog one for the VGA port. Some monitors have both analog and digital input capability and can automatically adapt to the the digital signal, even if applied to the VGA (analog) port. Other devices are not so smart and need an actual digital-to-analog converter style adapter.
Jul 06, 2016 | Acer XD1170D Projector
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
How do I connect the Acer netbook to the TV?
The only option is using the VGA port on the Aspire One to hook it up to the TV.
Your TV must have a VGA in port for your to be able to hook your computer to your TV. All you need is a regular VGA cord.
Mar 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
How do I connect my acer aspire 5050 to TV?
Since the Acer Aspire One D250 only has VGA output for its video, you will need a VGA cable to connect between the D250 and a TV that accepts VGA input as a video source. The sound is separate. A mini-stereo jack on an audio cable with two RCA phono plugs on the other end would be used to connect the D250 audio output (usually used for headphones) to the left and right audio inputs on the TV. You may need to use the TV setup screens to select the proper video and audio sources. With the TV on and proper video source selected, you now should be able to press Fn and F5 to get a menu in the middle of the D250's screen that allows you to select the video destination by holding down Fn key and pressing the F5 key repeatedly. The single large screen icon (3rd one from the left) is the one to select video output to VGA port only which would send it to your TV. The sound on the D250 does not need to be selected but you may wish to adjust its level and/or properties to be more suitable for TV.
Jan 19, 2011 | Acer Aspire One D250 Netbook
Can i connect my acer aspire 4730z to my television so i can watch dvds
Yes of course.
First of all you will need to identify the available input ports on your TV. An RCA port is generally standard nowadays and it consists of a red, a white and yellow coloured reception ports (the colours may differ between tvs, i.e black instead of red). The red and white are for stero sound and the yellow is for video.
Modern TV systems also have a VGA adapter which is small flat port like the ones on a computer screen. This is usually blue.
A third option is an S-Video port, which is round in shape.
To connect your laptop using the RCA port, you will need an S-Video to RCA converter. You connect the S-Video to the port on your latptop, and through the converter to the RCA yellow port on your TV. For sound you will use another cable that connects to the headphone jack on your laptop and then splits to a white and a red cable to connect to your TV.
If you have VGA port on your TV, then connect the VGA port on your laptop to the VGA port on your TV. No converters needed. For sound you will use the same approach as above.
To use the third option you will need to have an s-video out port on your laptop and you will connect it directly to your TV s-video port. For sound, again you will use the approach as the rca solution.
Then, using your remote control, select the AV mode or depending on your TV select the PC or VGA mode.
Finally, to transfer the video from your laptop to your TV press and hold the Fn key on your laptop's keyboard and then the F7 or F9 key. (It has s small TV icon on it).
That's it!
Regards,
nicolasiac
Apr 08, 2010 | Acer Aspire 4730-4947 Notebook
Can i plug a desktop monitor to a lap top?
Yes, if you have a video connector on the back of your laptop. Most often you will find a VGA type connector, which will work with most monitors and LCD's. The connection will look like this.
Hook the monitor up and turn it on.
Then, you will need to go into Control Panel, Display or Personalization
and choose to Extend you desktop, which will allow use of both monitors.
Here's a great tutorial on the subject...
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/monitors.mspx
Nov 01, 2009 | Acer Aspire 5050-3242 Notebook
Need to hook up laptop to TV
If you have an HDMI port you might also have an RGB port, use your tv video source button and go through your options. If RGB option is listed you have it. It's a standard moniter port, you can use a standard monitor cable to hook things up. This will not however carry sound so you'll need a basic 3.5mm size cable that ends in an RCA plug (can be picked up radio shack.
I use this method to watch hulu.com movies on my 50" plasma tv.
Another option if you have an "S" video on both the laptop and the tv, use that with just an "S" video cable.
Other wise look for a RGB cable that converts to standard RCA stereo plugs again Radio Shack should be able to help you. You can also buy cables on eBay a lot cheaper then a retail store.
Aug 19, 2009 | Acer Aspire 5720-6661 Notebook PC
How to connect acer laptop to philips tv to use tv as monitor
If your TV has a VGA input you can connect the laptop using a standard monitor cable. If the TV has component video inputs, you can get an adapter cable with a VGA plug on one end and the appropriate RCA plugs on the other.
Without these inputs, you can't connect the laptop directly. You will need a converter to switch from the computer's VGA output to a standard video signal to feed to the TV. Here is a website with a sample converter. (I don't know this site. It's just one I picked from a Google search as an example.)
Mar 23, 2009 | Philips Televison & Video
Acer Aspire One Netbook 8.9" Notebook Logo
2,491 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
