Question about Mitsubishi WS-55819 55" Rear Projection Television
Screen seems to have convex curves at the top and bottom of the screen. had it repaired once 3 years later the same thing. took the tech that came to the house said the heat expands the connections on the main board then contracts when you turn the tv off. 15 minutes to solder some points on the mother board good as new again. is this right? can it be that simple or is it something he's not telling me? Getting ready to call him again.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If it is convergence and was soldered once--it will most likely need the convergence chips replaced--this model uses two STK-392-570 chips----even if bad soldering was the first problem based on the fact that the set is a 2001 model--should have just replaced the chips then as the amount of work to get at them to solder is the same as changing them--if the chips are replaced the set should be good for 5-8 years--not 3 years.
Let me know if you have questions or need advice.
SD TECH
Posted on Sep 26, 2009
I have circular oblong lines repeating from the top of the screen to the bottom. I cam watch a show but, when the screen is dark the lines show up. they are sharp thin lines curved from edge to edge on...
Not that you want to hear it but its the begining of the end, you convergance i.c. is starting to go. I had this set a few years back and I fixed it once for around 350, then six months later it dies again. Parts for this style have jumped in cost so I would say 400-500 for repair
Nov 09, 2010 | Sony KP-57WS500 57" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Sony kp53hs30 screen is curved at top/bottom when in widescreen
on the sony we have to make the convergence alignments on all the modes, only a qualify tech can do that
Dec 17, 2008 | Sony KP-51HW40 51" Rear Projection...
PT-61G63 Convergance
Your convergence IC's most likely need to be changed, possibly some resistors as well.
Do you know how to solder and use a meter? If so you may be able to fix this yourself for under $100. If not you will need to repairman to repair it, this should cost around $300-$500 Let me know if you want to repair it so i can get you going.
Tim Nolan
Sep 12, 2008 | Panasonic PT-61G63 61 in. Rear Projection...
Mitsubishi prjection screen WS-65908
You have a convergence problem,all this sets show this problem sooner or later,you have 2 or 3 amps for the red,green blue colors and this amps go bad and need to be replaced then you have to do a convergence aligment from the service mode and not form the customer controls,a qualified tech should be able to correct the problem since is a common one.
Sep 09, 2008 | Mitsubishi WS-65908 TV
Mitsubishi Diamond Series CS-27609 problem...image looks "fisheye"
2 years later and I may have a solution for you
I has a similar problem and I didn't quite fix it but made it less noticeable.
Press menu and then the code 2-3-5-7, this enters a service menu. Press Audio/Video to go between the options to get to options 40-50 to adjust geometry. Be sure to write what setting there on before you change it (even if they're wrong) just in case.
Its just trial and error from there, and hope I can still help.
Oct 27, 2007 | Mitsubishi CS-27609 27" TV
PICTURE CURVED
I have the same problem, it is called the "bow tie" effect, I read in a forum a couple of years back it is because they started computer sodering instead via humans and it was not successful during that time. I bought mine in 02. I was hoping to find a picture of the the board and the specific soder joint on this forum. I hate to pay alot for a tech, (specially since it was mitsibitsi's poor craftmanship) and a 65" is not something you throw in the truck and take to them. Good Luck.
Oct 12, 2007 | Mitsubishi WS-65515 65" TV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Mitsubishi WS-55819 55" Rear Projection Television Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
