Question about HP Color LaserJet 2600n Printer
My HP 2600n, although has all 4 cartridges full, it prints an almost blank page. Any ideas ??
    Scholar:
  • 81 Answers
Ther are a lot of different issues which could be causing the problem
Best to eleminate the possible suspects
Elimate it is a paper issue by using a different paper, one that meets HPs specs
Check if it is a toner issue
If the 4 cartridges are almost full then you have replaced them fairly recently, or they are not genuine HP cartridges and the amount in the cartridges are not registering correctly
If you bought the cartridges recently are they genuinely HP, there a lot of good refillers out there but there are also a lot of cowboys in the industry. HP will only recommend there own toner cartridges, so replace the cartridges with new HP cartridges, at worse if the problem persists you can contact HP and tell them their consumables are faulty and let them tell you what your problem is
Were the cartridges removed from their protective packaging before installing and were they exposed to light for more than a few minutes
There is probablly a few things I have over looked, check out the link below
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&prodSeriesId=446153&objectID=c00316826#A3
Posted on Sep 26, 2009
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
Printer print only black while all cartridges are
Check your printer configuration and make sure you haven't mistakenly set it to monochrome (black and white).
Nov 27, 2009 | HP Color LaserJet 2600n Printer
I have two HP 2600N printers that print Yellow onto the whole page. Replaced Toner and it wont and worked for a short time and then got worse with the yellow on the page. One of the units says yellow toner...
Generally this is a toner cartridge issue. Are you using genuine toner cartridges or generic remanufactured? I have attended alot of repairs on this model when clients use generic cartridges. Usually a genuine cartridge fixes the problem.
Jul 13, 2009 | HP Color LaserJet 2600n Printer
Printing problems with Epsom DX4200
Hello sir; I believed that's installation problem, pull out each one and slide in again (push harder) see what happen.
Jun 23, 2009 | HP Color LaserJet 2600n Printer
I have a Hp Color Laserjet 2600n, I get a vertical blue sprip on my printed pages. What is the cause?
most probably the waste bin is full, try to shake the cartridge horizontally ang gently to distribute the waste evenly.
May 19, 2009 | HP Color LaserJet 2600n Printer
Hp 2600n will not accept print jobs. Color cartridges show empty. black shows half full. Printing of a test page produces a great test page quality
I have two problems. Either it won't accept a print job or when it is printing it stops when it is going through the job intermittently. Like for an hour it won't continue then all of a sudden it prints one page then a half hour later another page etc. It is so frustrating.
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Magenta covers entire page
I had a similar problem. See: http://www.fixya.com/PostQuestionTx.aspx?prdid=378544&ctgid=0&thid=1044936&type=2
Are you your replacement cartridge orignial HP?
I also had your problem on my previous HP printer (don't remember the model #). And I had it cleaned a couple of times, replaced the magenta cartridge (but with remanufactured), and could not get rid of the magenta. I gave up and bought a new 2600n, but now I wonder if I had used original HP parts if the problem would have been solved.
Sep 13, 2008 | HP Color LaserJet 2600n Printer
HP colour cartridge no. 22 won't print
if the test pages come out OK then the problem can not be the printer !!!!!!!
it must be from the application
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Epson c60 problem
methinks you'll need to do a clean and calibrate on those new ink stations.
May 11, 2008 | HP PhotoSmart 7260 InkJet Printer
HP Officejet 6210 printing blank pages
Hi steve well I suggest that you remove the cartridges and clean the little gold contacts on the carriage and the cartridge. If this doesn't work then install brand new original cartridges as the cartridegs that you have refilled the data ribbon may have been damaged when you refilled them..
Try the above and I hope it works for you
Thanks J
Oct 23, 2007 | HP LaserJet 4 plus Printer
HP Color LaserJet 2600n Printer Logo
118 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
