Question about Dell Inspiron 6400 Notebook
I cant download from the Internet . i put arrow on download click it and a yellow burst and click sound happens.
    Sergeant:
    Champion:
  • 232 Answers
Your setting on your computer are not correctly set .
Click on start , then click on control panel , click on internet properties then advance tab .
tick on enable third party browser extentions .
if this does not work , try the same process but instead of tick the third party browser extentions box , click on restore advance setting below the main box and that should fix it .
Make sure to do all these action while you are not online or having your browser open .
Posted on Sep 26, 2009
Natwest personal banking
This would be an internet connection problem ?
You will have to open up your network connections.
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled.
Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question/ Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device
You only need check the following if you cant install the driver
Make sure you Ethernet/internet is enabled in bios.
Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press Enter make sure its enabled
then recheck the driveri t should be there
k the driver it should be there
make sure its enabledPci device arrows key scroll to nstalled
if you computer came with a motherboard disk the driver could be on it
or this disk provided by your ISP provider Internet Service Provider
or you might have to download one
Apr 01, 2014 | Computers & Internet
Gateway e2610d computer
Check all ethernet ,usb leads and connections for any breaks bends and secure connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver or you could download one
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
http://download.cnet.com/2000-20_4.html
on the homepage you will see a search bar type in the ethernet controller freeware you want/need
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html
i device arrows key scroll to nstalled.
Sep 12, 2013 | Computers & Internet
Nointernet
"Enabled"ima
i device arrows key scroll to installed.
Aug 12, 2013 | Computers & Internet
I cannot access the Internet since February 2013. Had 100% internet connection before that.
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 or you could download one cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html i device arrows key scroll to nstalled.
Apr 02, 2013 | Samsung Galaxy Note 10.1"
Try to setup viewnetcam
Step 1:
Apr 02, 2013 | Panasonic BL-C30A Network Camera
I reinstalled windows xp on my hp dc7600 small form desktop unfortunately i have lost my network adapter driver so i cannot access the internet to fix this problem however i do have accesss to another...
You will have to open up your network connections. Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled. Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question / Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device You only need check the following if you cant install the driver Make sure you Ethernet/internet is enabled in bios. Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press Enter make sure its enabled then recheck the driveri t should be there k the driver it should be there make sure its enabledPci device arrows key scroll to nstalled if you computer came with a motherboard disk the driver could be on it or this disk provided by your ISP provider Internet Service Provider or you might have to download one http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Mar 03, 2013 | HP Compaq dc7600 Convertible Minitower PC...
Having trouble connecting to internet
Wireless or Hard wired ethernet ?
Feb 27, 2013 | HP Compaq 610 T5870 156 WH248UTABA...
My new dongle says no network when I put it in, whats wrong?
Feb 14, 2013 | Advent 4211c Notebook
I cannot get my internet connection working although it was on Sunday
Wireless ? or Landline ?
Feb 12, 2013 | Computers & Internet
Can you download a sound card ?
no you cant download a sound card but you can download a sound cards drivers
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
hope this helps
Apr 27, 2011 | Apple Computers & Internet
Dell Inspiron 6400 Notebook Logo
69 people viewed this question
Alun Cox
