Question about Acer Aspire L100 PC Desktop
At the front of computer, the 2 usb are not working
At the front of computer, the 2 usb ports+headphone&mic connections are not working.
    President:
  • 942 Answers
By the way that kind of port is an optional to function, because it is not an onboard port not like the port at the back. The front port is disabled if the connector inside is not connected. If you want this port functioning you need to open your CPU casing and locate the ping which is the connector to be connected.
Regards
PCmania
Posted on Sep 26, 2009
  • 6,831 Answers
Hello
If you have recently formatted or opened your case, this might just be a case of some wires not pluged in correctly, or chipset drivers not installed. Try installing chipset drivers again, if that does not work open your case and trace the wires back from the front panel and plug them out and back in again. Really hope this can help you.Please rate this.
Best regards
I can not hear anything with it on
the speakers might be muffeled from the felt cover
Dec 20, 2009 | Microsoft LifeChat™ LX-3000 Headset
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
How can i use headphone's mic on my acer aspire4720z?
there are some ports in the front side of your laptop...try with one headphone with mic....please connect the ports with the cables of the headphone...
Front panel connectors/jacks is not working
OK--usually what you will find from the front is 3 connectors.
One will be a solid block that has one blank hole which is the key. That will plug into the corresponding pins on the motherboard--usually toward the back of the case.
There will be another other wire that terminates in two plastic connectors. These are the USB connectors. Sometimes the connectors are in two parts. One is a 3-hole and one is a 1-hole. Usually you will find two sets as they sort of go together.
The pin configuration on the motherboard looks like this ::::.
The single pin on the end is not used. The other ones are connected with the plastic connector on the first three starting at the left, with the end marked VCC to the left. The fourth pin is the ground which is usually the separate connector.
The second USB connectors are plugged in right next to the first--so each block of pins controls 2 USB ports.
Hope this helps.
May 14, 2009 | ASUS Computers & Internet
Front headphoes and front usb ports
maybe the wire connection of your front panel audio is not connected to your motherboard, try to have it checked by a pc
technician.
Aug 09, 2008 | ASUS Vento 3600 Dream Extreme Gaming ATX...
Front mic port and headphone
to connect your front panel header you must refer to your motherboard manual ...
it will given in detail with the pin diagram how to connect ....
check the motherboard compatibility some motherboards dont support working of the back panel header and front panel header at same time especially the old motherboards ....
almost all new motherboard supports working of both the panel headers at the same time if the motherboard supports multi streaming...
thank you
any doubts you can reply me
i am always here to assist you
bye
rate my solution
Aug 06, 2008 | Computers & Internet
Headphones with mic / external speakers
Does your computer have front audio ports? If so, you can just plug it in there. Otherwise you need a single male 2 dual female converter to plug into the speaker port.
Jun 21, 2008 | Computers & Internet
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
Mic port not working
1. Check the Audio I/O settings in Realtek Audio Manager in system Tray Icon on Taskbar,
2. Try to connect your Mic to Front pannel of system Unit.
or Reinstall audio Drivers.
Feb 22, 2008 | Intel D101GGC Motherboard
Acer Aspire L100 PC Desktop Logo
144 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
