Question about LG Computers & Internet
When my monitor resolution is set to up to 1024x768 the display is distorted
  • 6,831 Answers
Hello
I dont sknow if this is the case here, but try setting your frequency as well. It worked for me. Realy hope this can work for you to. Please rate this.
Best regards
Posted on Sep 26, 2009
My Mac will not install the Digital camera Solution Disk says my screen resolution is insufficient...
This must be because you have a widescreen monitor or because you have set a screen resolution that's too low for anything.
Most programs ask for a screen resolution higher than 1024x768 (which they rarely actually need) to install.
So you can change yours to that value (or higher) for the installation and if it distorts your display, set it back to the original value later.
To see how to change your resolution, go to this site; http://www.ehow.com/how_2064940_change-display-resolution-mac-osxchange-display-resolution-mac-osx.html
After setting the resolution to 1024x768 or higher, run the installation and it should proceed with no problems.
May 04, 2011 | Canon A3300 IS Digital Camera
TheLCD is not working on resulution 1024x768 do i need any driver
Yes, it is very possibility of driver problem, but you can check it to attached with another PC. If the problem will persist you need to drivers. And another possibility is the LCD did not support 1024x768 resolution.
Good Luck
Mar 04, 2011 | Hyundai Electronics L19T+ LCD-TV 19"...
How do I get my gateway fpd1975w tft lcd monitor to not stretch images images across the screen?
You need to make sure your computer's display resolution is set to 1440x900, which is the monitor's native resolution. Other resolutions will result in fuzzy displays or, as you're seeing, distorted images.
Right-click on an open area of the Windows desktop (that is, not over any icons), then select "Properties" from the pop-up menu. Click the "Settings" tab and you'll find a slider adjustment to set the resolution. If 1440x900 is not offered as a resolution, you'll need to upgrade your video card (or add a video card if you have a motherboard with integrated video). Most newer computers support that resolution, but some older systems may only go to 1024x768.
Thanks for using Fixya!
Oct 20, 2010 | Gateway FPD1975W 19" LCD Monitor
Resolution notice it says the best picture quality change to resalition to 1024x768 1 exit 2 disable how do i get rid of it
LCD monitors have what is called a native resolution. This is what the actual/physical display resolution is. When you try to display outside of this then you get the error. The easiest way to get rid of this is to set you video display resolution to the native monitor resolution.
If you look at the message it is saying if you hit 2 it will disable the error. To change the resolution in windows you can just right click anywhere on the desktop that is empty. This brings up the display properties. Go to the settings tab. At the lower left is a slider. Just slide it to show the desired display size in your case try the 1024x768 setting then hit apply. The screen will change and a nother window should pop up and ask if you want to keep the settings. If you take too long or say no it just resets to the prior settings. You can change it at any time.
1024x768 is a good setting it is high enough that the display is clean and sharp. And most web pages are designed around this size. Try it not only to get rid of the error but also to see what everything looks like. You can always change it back.
May 05, 2010 | Belinea 10 15 36 15" LCD Monitor
If connected to a 64 bit Dell Studio, it is difficult to view monitor. can you help? It works perfectly on a HP pavilion, but not the dell
Your resolution is probably not set correctly. That monitor can only support a resolution of 1024x768 - so to change that, you'll need to go into Start - Control Panel - Display Settings, and then click on the settings tab, and near the bottom where it says "display resolution" drag the slider until it says 1024x768. Press apply or ok and see if that helps.
Jan 20, 2010 | Mag Innovision lt456s 14" Flat Panel LCD...
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Change the display resolution from 1024x768 to1024X1280
go to control panel > dosplay settings > click on the settings tab > click on the advanced button > c.ick on Monitor and tick the box that states "Hide Modes that this monitor cannot display > click the adapter tab > click on button "List all modes" This will list every resolution your monitor is capable of displaying.
Sep 17, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
Tried hooking the computer to an external monitor. Got the welcome screen ok, then it lost sync and went black. Tried it on another plasma; same result. SVGA cable connection.
Hi there. When you connect an external display, your laptop clones your desktop to the external display, including resolution settings. First you need to check what resolution settings the plasma can display. If your laptop is set to a resolution that the external monitor can't display, then you will lose the display once the resolution settings are loaded. You can change the laptop resolution in your Display Settings.
If you don't know what settings the external monitor can display, just open your Display Settings and set your laptop resolution to 1024x768. Almost all new monitor/tv's can display it. Connect your external display, and see what happens. If it works, but the resolution doesn't look right, then just move the resolution along one more, until you find one you're comfortable with.
N.B. Some monitors/tv's "jump" resolutions. i.e. the monitor can display 1024x768, 1300x768, but not 1280x800.
Another thing to remember is that if you are running Windows Vista, you may need to check that the Windows Mobility Center recognises the external display that you are trying to use. You can find Windows Mobility Center by clicking Control Panel, then Mobile PC. It should now be listed on the screen.
Let me know how it goes, and if it works, please rate.
Tim
Apr 17, 2009 | HP Presario V2401cl Notebook
Need Help Setting Up Monitor
Basically the monitor wants your video card to feed it the display at a resolution of 1024 by 768 pixels. The 60Hz is the frequency and is standard for lcd monitors. Since the monitor is designed for 1024X768, it is shutting itself off in order to prevent damage.
To change your resolution (I'm assuming you have Windows), right click on a blank area on your desktop and select Properties from the list that pops up. The Display Properties windows will open, click on settings and change it to 1024X768. Next click on the Advanced button and then the Monitor tab and make sure the refresh rate is set to 60 Hertz
Oct 01, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
My new 19 inch 1952 LG monitor stretched my display picture from what I use to have on my 17 inch. How do I adjust the height to width ratio for a picture that isn't distorted?
Right-click your desktop, click properties
go to 'settings' and select the 19 inch monitor
now change the resolution to the format you want to use.
Set it to something like 1600x1200, or 1024x768
Apr 04, 2008 | Computers & Internet
Computers & Internet Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
