Question about GE Profile JTP18 Electric Single Oven
Door Keeps Locking and Unlocking after Power Outage
About one hour into a cleaning cycle of my JTP18, the power went out for about six hours. When the power came back on, I reset the clock, but noticed that the display was flashing LOCKED DOOR, and I could hear the motorized door latch continually locking and unlocking the door. Pressing CLEAR has no effect. If I press the SELF CLEAN button, then START, it looks like a clean cycle is starting, but it really isn't. The door keeps on locking and unlocking, endlessly. Pressing any button for a normal oven function makes the display show the word "door".
  • Werty55 Dec 18, 2007
    I found the solution in proover's posting. A thermostatic switch opened when the cooling fan was no longer running because of the power outage and the control area got too hot. The service paper taped in the control bay of the oven stated that the switch would open at 220°F and needed to be manually reset. The switch was mounted to the bottom of the control bay (top of the oven), directly in front of the fan. There was a small button on the backside of the thermostatic switch. When I pressed it, there was a single "click", and that was it. Turned the power back on to the oven, and everything's functioning normally once again.
    Thanks, proover, for posting your finding!!
  • thanft Jul 11, 2008
    Having the exact same issue but having trouble locating the thermostatic switch to reset in the oven - can someone offer a more detailed explanation of how to find the switch in order to reset?
Located the switch - resetting fixed my stove as well.
Posted on Jul 14, 2008
I have a GE model JGBP335 gas oven. Since power outage about 3 wks ago it flashes "unlock door" when you try to preheat oven. The oven will not come on at all. We have tried unlocking and locking door...
I would suggest set unit in self clean then cancel, this should rotate the lock and reset the lock position for you, apparently the unit was in a cycle when the power issue accrued and is unable to reset on its own. Try this and see if this corrects this issue for you.
Good Luck
Dec 06, 2013 | Ovens
Viking deso175ss ran self clean cycle, tried to stop the cycle early. oven door locked wont reset. tried turning power on/off. was able to get door open by pushing latch to left, however it still will not...
Hello, welcome to FixYa.
I understand you have a Vking oven that is not unlocking after stopping (interupting) a self clean cycle, correct ? (I think the letters in the model should be "DSOE" as opposed to deso, aren't they ?)
Though this can cause issue's with the lock mechanism, it is unlikely anything was my opinion of course, thus I don't think you need to start swapping parts.
If this hasn't already been done, I would suggest prepairing your oven as if everything was status quo for a self clean cycle.
Close the door, select self clean and let it go through it's start-up and lock sequence. Your going to stop it again, just as Viking instructs pressing "off" which should allow the lock mechanism to properly lock and then unlock.
During the clean cycle the unit usually has to cool before allowing for the door to open which can take up to 30 minutes, (this is why it counts down from 4 hrs even though the cycle is 3.5 hours) but since it should already be cool I'm hoping the lock will go a full revolution to it's normal position.
Normally these ovens will go through a self check sequence upon a power up (if power was lost and then restored...aka "onboard watchdog") which should include the lock assembly rotating to it's unlock position, but they can get out of sequence at times in my experience.
The other method I've tried and had success with is having a secone person hold the door switch closed while power is turned off and then restored a few minutes later.
Let me know if you have tried that and if not try it and get back to me. Hopefully that will restore it's proper function. Good luck.
Macmarkus :)
Sep 07, 2011 | Ovens
My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
Lock light on frigdaire self cleaning oven
OK, this is not a good situation here. your Electronic Oven Control board is damaged. the logic sectors are faulty. The F-1 represents a major EOC failuer and, you will need to replace your EOC(clock) asap, if possible.
Jun 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Accidently started clean, food inside,hit cancel,can't open
you would have to disassemble the cook top in order to get the the locking mechanism to manualy unlockit
May 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
How much time to leave on self cleaning...clock does no work
Depending on the condition of the oven, it could take up to 4 hours.
I ran the auto self clean on my oven last week for the first time and it set automatically for 3 1/2 hours. (It stunk, but it worked.)
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Dec 15, 2008 | GE Profile JTP18 Electric Single Oven
How to self clean
Here is a link for your stove:
GE JTP18 Manual
Directions are on page 23.
Dec 13, 2008 | GE Profile JTP18 Electric Single Oven
What is the reset button for GE Profile JTP18?
For me the solution was in the temperature sensor. The Locked light kept flashing and the door locking mechanism kept cycling when the door was shut or if I just held the oven light switch in the closed door position. After replacing the control panel I still had the same problem. Next I turned off the breaker and then took off the wire covers on the back of the oven and disconnected the temperature sensor. I then checked the continuity of the sensor which was fine. With the sensor still unplugged, I turned the breaker back on and the panel said locked but the locking mechanism was not cycling. With power still on to the oven I connected the temperature sensor. It worked. All I had to do was press the clear button on the touch panel and everything was fine. I turned the breaker back off and reassembled the oven. Hope this helps.
Oct 12, 2008 | GE Profile JTP18 Electric Single Oven
DOOR Locked Flashing
check the interlock switch, can be some object has stuck to it...
Sep 06, 2008 | GE Profile JTP18 Electric Single Oven
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix....
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
747 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
