Question about IBM ThinkPad T30 2366 Notebook
IBM T30 - no screen - sortof booting
I gotta say that even in 2007 I prefer an old T30 to most other laptops. So I'd really like to get mine working again.
Was having the notorious bad ramslot problem for a while, then the problem went to the other ramslot. Of cause this resulted in the 1..234 beep 'no ram' error message, but one day it stopped doing event that.
So, I took it apart and extracted the motherboard to see if a touch up job on RAM slots might fix it. Also removed cmos battery. Was without cmos power for about 3 days. I hadn't read anywhere that this could be an issue.
Got tired of waiting for a friend to have some spare time to do the solder job so I put it back together, where the new problem occurs:
Powers up with normal green light activity.
HDD & CDROM powers up, but is not accessed by board.
Nothing on the external monitor.
Will beep now if no RAM is detected (removed both modules).
CPU fan revs up, then down, then up again in a cycle (this isn't normal).
battery still charges from mains
Is this a totally dead board or not? Is it fixable or should I just ebay for a T30 with a broken screen?
  • 2 more comments
  • discostu Dec 24, 2007
    No dice. Thanks for the tip though, I always wondered what some of the other functions did.
    Seems to not be posting even though there is a positive sign from the lights.
    I think the strange fan behaviour might be an indicator of a bad problem, I'm just not sure what.
  • discostu Jan 22, 2008
    Hrrmmm. Not sure, I'll give it a shot next week when I'm back at my own place (doing a bit of travelling).
  • discostu Feb 19, 2008
    Hi again. Sorry for the big delay.
    Anyway, I've got got ahold of the aptop again and this time I just decided to press the power button one more time and see what happens. Well, the bios posted on the screen but after a few seconds of the ibm splash screen it said fan error.
    I opened it up and fiddled a bit, put it back together and this time it worked!
    However, the whole thing is still totally unstable. After trying to install ubuntu, it froze. Thinking this was just 'one of those things' I tried again, but it keeps freezing in different spots. I think the boards just had it, the one ram slot is still not working and I think the other slot just fizzles every now and then. Also, it's about one out of 20 shots it will boot. When it won't boot, it's the same problems as before the fan was fixed (IE, lights but nothing works, not even the little lid light).
    Oh, the laptop always recognizes a lack of ram on bootup, so I don't think having both ramslots dud is the problems.
    I'm going to ebay for a new motherboard, I'll post when it's done.
  • discostu Mar 11, 2008
    Hhahahaha, yeah I smacked mine around a bit too. Seemed to work for the first few times, but as always do this makes matters worse.
    Mine ran really well for a month after the first episode of bad ram and I fiddled with it for a bit (swapping modules, pressing down on it), I think the bad solder joint really is to blame.
    My last ditch effort to get this going again will be to ebay for a new motherboard as it costs way too much for a pro to redo the solder joints.
I own a t-30 myself with all the same problems i am reading about not reading ram beeping on startup no screen display but you could here hard drive running before these symptoms started the first symptom i ever noticed was if i picked the unit up with my left hand on the left front corner to move it it would boot down and then would not re boot properly (no screen, beeping) until i would smack the case then it would boot fine note: ram slots are located in the left front corner. I always assumed i had a cold or broken solder joint on the main board the last week the thing started running flakey i noticed i was only reading one of my 256mb ram chips so i powered down switched the two chips to the other ram slots and rebooted i noticed one chip was really warm the other cold the comp. booted up perfect and ran perfect for 2 hrs. same prob. so i bought two new 512mb chips installed the and have had none of the above listed problems ever since
Posted on Feb 23, 2008
    Problem Solver:
  • 9 Answers
Your screen brightness might be turned down press the “Fn” and “Home” keys to increases your brightness.
Try pressing the “Fn” key along with the “F7” key at the same time after your laptop has been powered up for a few seconds. Pressing these two keys at the the same time tells the laptop to switch between the external VGA connector and your LCD screen. If you still don’t have video try hooking up an external monitor to the VGA connector and press the same keys mentioned above to see if you get video.
Let me know if this helps.
Posted on Dec 17, 2007
  • Lynn Smith Dec 27, 2007
    Humm... Does the fan still actup when the RAM is removed and the laptop beeps at you?
IBM Thinkpad T30 2366 won't boot after the IBM Thinkpad screen
you can go to the BIOS setting? if you can,look for "Boot Device Priority" or something like that,it's usually placed on Advanced settings. Set the first boot device as your harddisk,save the settings and restart your computer
Please let me know if it's working or not
Aug 28, 2012 | IBM ThinkPad T30 2366 Notebook
T30 Intermittent Booting Problems - Depending on screen angle
It is issue with the screen cable connection. Replace it. or it is getting chaffed and causing issue in proper signal and power to the screen. It is hardware issue.
Apr 24, 2009 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2367
I bet your hard drive crashed on you. You might have to buy yourself a new hard drive and replace your old one with it. Then format it and install a fresh copy of your Operating System on it. Your error condes here indicate to me that you either got a blue screen or similar. Blue Screens and/or the code that you stated here are usually caused by a software issue, and are rarely hardware issues. But in this case, you may have gotten something bad on your computer, such as a virus or serious spyware, that wiped out your Operating System And caused your hard drive to crash/become corrupt. As I mentioned, try replacing your hard drive. Hope this helps.
Sep 07, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 2367 beeps 8 times
It's your memory, or more to the point, the memory slots. take all memory out, install 1 piece in the slot closest to the back of the laptop, push down on the memory as if pushing it into the motherboard, and hold pressure while booting.
Bet that works. if not, let me know.
I've got the same machine.
Good luck
Jan 03, 2008 | IBM ThinkPad T30 2366 Notebook
IBM T30 Screen Problems
More likely than a cracked screen was a bad connector. Having a band (vertical or horizontal) of random lines and colrs is typical of a bad connector. Odd as it may sound, you can try to diagnose whether this is really the case by squeezing carefully (not too hard) around the edges of the screen. On many different models you will find that when you get to a certain spot and squeeze lightly the problem will change or even disappear temporarily. For the more adventruous you can also try lightly twisting the casing. I've had this work on dozens of machines with similar symptoms.
Sep 25, 2007 | IBM ThinkPad T30 2366 Notebook
IBM T30 Start Up Problem
see website, sev eral ways to test this problem
Mar 28, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
507 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
