Zenith TV model# D36D51 Picture started blinking on & off then sides were squiggly, blinking,& no picture then pic come back ,blinking, & squiggly lines. I figured it was the board had gone bad but before I junked it a friend & I took back off looking for anything not right. He touched a box on the bottom ,it flashed blue & shocked him. Box had three turn knobs focus, focus, & screen.#'s on box were 01402 FEC02 E216413 Mexico P95-4646-03 & was stamped inspection stamp. and another number on front of box was DU27A or DJ27A LD18 LD18 Please help me, struggling single mother of 2 very active pre teens.Cannot afford labor costs. Have access to parts supply companies. willing to try fix self.
  • 5,138 Answers
Call Mats for screen/focus control box 1-800-628-1118 for Zenith Boards Call Zenith Exchange 1-800-632-6637
Posted on Sep 26, 2009
Picture blinks on an off an has no sound how can this be fixed
TV pic blinks on/off when connected to satellite via hdmi - Forums ...
www.cnet.com > Forums > Sony
CNETApr 7, 2013 - We have a sony bravia LCD tv, model KDL-60EX500. ... The tv then started "blinking" on and off - no sound, black screen - for a half second or ... Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
LG TV : Picture not coming on screen, but TV is on.
Jul 14, 2014
How many have 'blinking' issue with Samsung led tv
Jan 26, 2011
More results from www.cnet.com
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
VIZIO flickering Tv screen easy fix( no money ) .... I left town unplugged the Tv. When I came home home ...
Jan 26, 2016 | Televison & Video
Zenith C27A24T 27" TV -
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board (also on circuit board that is fixed to CRT TUBE ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears or rolls ( in your case )...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 21, 2011 | Zenith C27A24T 27" TV
No picture, just sound. picture will eventually come back after hitting the side of tv a few times.
in some computer CRT monitors & CRT TVs after 4 or 5 years cracks develops at some soldering points - then due to loose contact picture disappears...when we hit ....those loose contacts joins temporarly & so again picture appears...so solution is TV circuit board should be observed carefully & at most of the soldering points - dry soldering should be done....100% your TV will work.......so if you are a technical person & if you have soldering iron & tools to open backside cover then you can do it or else approach a good service engineer..............iam babu - service engineer ( computers, laptops, printers, etc..) - bangalore - domlur - 09986222774 - sathyavijayasarathibabu@ymail.com
Apr 14, 2011 | Zenith C27V22 27" TV
Hello , i have a zenith hd tv model d36d51 the flyback went bad. I replaced the flyback and now i have a different color in each corner of the screen, also there is a 1/2 round disc that looks like its...
Your colored corners are from a magnetized screen. That disk you talk about is a thermistor and is necessary to clean the screen by demagnetizing the picture tube. Not serious though, hav e a tv tech degauss the screen externally. OH YES! is this disk in good condition or is it separated from one of the legs or broke. You may have to replace it!
Dec 19, 2009 | Zenith D36D51 36" TV
There is a hissing noise in back of tv and picture goes on and off zenith d36d51
Hissing noise and picture on and off means faulty flyback transformer, it has a small crack and voltage is leaking out, replace the flyback, if tv still not working replace horizontal output transistor (broken flyback could blow the transistor).
Aug 09, 2009 | Zenith D36D51 36" TV
52 Inch Zenith TV has red blue and green squiggly lines what is wrong, no picture
I belive that the red light means that it is off and the blue means that its on
Jun 10, 2009 | Zenith D52WLCD 52" Rear Projection...
No picture at all, black screen, audio works , cant work menu cant see it
sounds like video problem take to tv shop they will address your problem okay good luck
May 02, 2009 | Televison & Video
Z50px2d
Technician just replaced the upper right (from the back) circuit board that conects to the panel. TV now works fine. I bought the display model 8 months ago with extended Circuit City Warranty for $1000 so I can't complain. This was covered entirly by LG/Zenith (nicest Cust. Svc. ever) so we'll wait and see what happens.
Dec 10, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith tv no pic
You have a picture when you're watching a DVD, but none when you're watching regular cable? Does the audio appear to be okay?? Are you sure you've switched the inputs on the TV back to main???
Let me know..
Bill
Dec 08, 2007 | Zenith B25A24Z 25" TV
Mitsubishi 6071 April 1994 NEED HELP!!!
these sets have bad connections in the picture yokes take the spekerr grill off and front cover move the wires around and see if the pic comes back be careful ok
Oct 03, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Electro Med Services...
