LG GSA 4163B DVD±RW Dual Layer Burner
Problem for LG GSA 4163B DVD±RW Dual Layer Burner
My divice show conflicts
By sthamae126 on Sep 26, 2009
when i go into the divice manager,i found that there is yellow exclamation mark on my cd/dvd rom
Solution #1
posted on Nov 03, 2009
Not Rated)
ishaquekvm
Rank: Wiz
Rating: 75%, 59 votes
1. Start > Run.
2. regedit
3. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class in the Registry Editor dialog box and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder.
4. Select File > Export
5. save the file to the Desktop in case you need to restore it
6. In the right panel of the Registry Editor, select the LowerFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box.
7. Do the same for the UpperFilters line
8. Close the Registry Editor.
9. Restart Windows.
Was this helpful?
Yes
No
Solution #2
posted on Sep 26, 2009
Not Rated)
fogfreak
Rank: Wiz
Rating: 84%, 51 votes
You can right-click on the drive and go to properties, and from there you can update the drivers or see the message about what is wrong with the device. However, these messages are totally vague and inaccurate, and even if it says the device is broken or something it's probably a software issue. If the cd-rom drives mount properly and you can see them in my computer and use them, it might be better to just let it be, lest you anger the gods of phantom software problems.
Anyway, the easiest thing to do is right-click on the cd-rom drive and remove or delete it. This sounds scary but a few later, or after a restart at most, your computer will realize it has the cd-rom drive hooked up to it, and automatically install it as a cd drive and might work. There's a chance that it's such an exotic cd drive you have there that windows can't find the drivers for it, but that rarely happens with something like a cd drive. If you think you need drivers for it, go to the manufacturer's website of the cd rom, or look in the properties and see the model name and google drivers for that. If your computer was bought already built (like an hp, compaq, dell) then you can probably find drivers on their website. If you computer was custom built you should try the site of the motherboard manufacturer.
It's possible that this could be caused by a registry problem. Sometimes when you install programs (itunes is notorious for this) they will mess up something on the computer by trying to make it compatible with them. So if your cd drives don't show up in my computer, you can download a file called cdgone.reg from the internet. I've uploaded the file to rapidshare, and you can download it from this link. I'll tell you myself that opening a random registry file you downloaded from some website is more risky than an unprotected romp with a lady of the evening, I give my word that file is safe, can you really trust me? Get yourself some virus protection, and there are some free utilities that will fix problems like your cd drive problem automatically.
Was this helpful?
Yes
No
Popular Solutions for LG GSA 4163B DVD±RW Dual
Questions and Unsolved Problems for LG GSA 4163B DVD±RW Dual
Do you recommend LG GSA 4163B DVD±RW Dual Layer Burner?
Answer
Answer
Is the eMachines LG GSA-4163B DVD±RW DL Burner compatible with the model T6212 desktop pc?... (More)
Answer
mY hl-dt-stdvdram gsa-t40ata when I go to panel control have a exclamation simbol an then said thata... (More)
Answer
unable to burn dvd9 with a duel layer disc in this drive
Answer
Windows cannot start this hardware device because its configuration information (in the registry) is... (More)
Answer
hl-dt-st dvdram gsa-t40n ata device for medion (my driver of dvd station is gone) this is the driver... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD... Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
