-   I accidentally unplugged the three front panel cables (1. Red & White 2. Blue & White 3. Black & White). I do not know where the pins should be placed.
Well I can tell you that the white wires are negative. The colored wires are positive. Do you still have your manual? Never mind that. There is not a description reference to show you how & where the connectors connect to the board. I would say the two "Black & white", connect the case speaker, most Pc's the negative would face to your right looking in at the board. "Blue & white" would be the reset switch & red & white most likely is the "Power Led". Good luck.
Hi As a layman in HTPC i had managed to build an HTPC searching on net. Please help me to install an...
(More)
Hi As a layman in HTPC i had managed to build an HTPC searching on net. Please help me to install an remote which will run software like vlc,kmp etc.
