Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Power issue i think
Have had my mine for almost a year and all of a suddenly it will not turn on ... it will flash the reset button on the front but nothing else ... any help would be appreciated
I am having the same problem. Please advise if solution found.
wrbogart@k-inc.com
Posted on Jan 14, 2008
  • dick flora Jan 14, 2008
    I to think it is a power issue. I find if I hold the button in sometimes it will work. Does yours make noise at first?
Lamp cut off, power light(green) flashing, ready light (orange) off
deffo the bulb life. not a cheap fix as bulbs are very expensive. reset the unit by holding a few buttons.mine resets by holding 2 buttons while off. google master reset for your model and you might get some more user time from the bulb. change bulb asap tho
Mar 08, 2014 | Dukane ImagePro 8039B LCD Projector...
Reset button?
Mostly, it's gonna be with your camera battery,
try switching it for a new one,
it's gonna cost like 20 bucks or so,
It happened with mine too and that's why I feel your pain xD
Dec 10, 2013 | Sony DSC-S930 Digital Camera
Canon mp190-eror e5
Hello and Welcome to FixYa!
Try to reset the printer, follow the instructions;
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
May 07, 2011 | Canon PIXMA MP190 All-In-One InkJet...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Prolems with the power.
Try leaving it off and unplugged for a while then hold power button while pluging back in to reset. Most brands of tv's flash to display trouble code.
Mar 15, 2010 | Jwin JV-DTV3212 32 in. HD-Ready LCD...
Wont turn on just flashes.wont turn off just flashes...Is there a reset button??All of a sudden it just stopped and started flashing no warning.
First try to turn off PC by holding power button for more than 5 seconds. Make sure first that your PC is clean inside and CPU is properly connected to motherboard (before you touch inside your PC touch some metal to discharge electrostatic). If it needs cleaning use canned air and paintbrush. Check how memory is connected. Check the Power Supply voltage, if it's ok, first turn PC off,then you can check power button by disconnecting ATX 20 or 24 pin power connector from motherboard and connect paperclip edges to any green to black wires it has to power on your PC. If it's still flashes it's more likely PSU or motherboard issue.
Jan 15, 2010 | HP OfficeMax - CPQ SR1638 NX-B Desktop....
I have E3 error code on a Bosch washing machine maxx classic - what does it mean? thx!
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Jun 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Projector will not turn on. No lights no nothing
I opened mine up and in th front was a red reset button now I'm good!
May 22, 2009 | Sharp XR-11XC Multimedia Projector
Error contiually flashes
may be try to check ur cartidges or replace them with new ones or check out if there is any paper jam.
Jun 04, 2008 | HP Officejet J5780 All-In-One Printer
Printer reset re Brother HL 1230
Resetting the printer should clear the flashing leds (flashing lights.)
How to Perform A Factory Reset:
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button. Hold in
the circular button on the front panel again. Once the Alarm light comes
on, let go of the button. This has performed a factory reset on the printer.
If the alarm continues, the printer may need service.
This issue is listed by Brother. Click here to view
Oct 22, 2007 | Brother HL 1230 Laser Printer
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
