Question about Hitachi 43UWX10B 43" Rear Projection Television
It needsre- align the projection bulbs to get rid of the double image
It needs an adjustment to re- align the projection bulbs to get rid of the double image
    Genius:
  • 1,694 Answers
More than adjustment...needs convergence circuit IC's replaced.
STK392-110 subs to upgrade STK394-160E Hitachi CZ 01341..
then use magic focus........................................T.
Posted on Dec 17, 2007
Double image mitsubishi wd-60735 have to cut tv off let cool down cut back on to get rid of double image
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 23, 2009 | Mitsubishi WD-60735 Projection Television
Pink and green color out of focus people have one green hand extended with another pink hand double exposed features. Tried to adjust the color convergence and it won't work and it is all out of line and...
The mirror that projects the image on the screen from the lights below is most likely out of alignment, this is a very delicate adjustment to make. If your not familure with doing this, it will need to go to a shop. I hope this helps, if you have any other questions please contact me. Good luck.
Sep 23, 2009 | Toshiba 43H71 43" Rear Projection...
The picture is double pictured with what appears to be a ghost
projection sets on occation need to be re-alligned. check your owners manual if you have one and re-align your lamps to the test screen that is displayed when you press 'menu' from your remote or from the front of the tv. This should fix alot of it and you may find the color adjustments may need adjusting after re-aligning your lamps. hope this helps. I had one and that sounds like the 'ghost' images I had till I did this.
Aug 11, 2009 | Toshiba 55H70 55" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Double image on screen
*Screen Looks 3-D
*Colors wont align
Jan 22, 2009 | Sony KP-53S75 53" Rear Projection...
I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Nov 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Screen appears curved on top and bottom
One or more colors can't be adjusted when when using the convergence menu. Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 22, 2008 | Philips 55PW9363 55" Rear Projection...
Projection Tv Problem
some of these tvs have internal adjustments for everything including alignment which fixes the double image problem. if you remove the cover you will find a lot of little adjustment dials. you may find that they have symbols that show what the adjustment is for. if you want more info. email me at sb1216us@yahoo.com
Sep 23, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
119 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
