Question about Microsoft Xbox 360 Console
SCREEN FREEZES, GOES SNOWY AND LOOKS LIKE MATRIX LINES AND NOISE GOING ON
    Novelist:
  • 168 Answers
This i have seen before and it tells me the machines is displaying the signs of lead free solder failure (85%sure). you could strip the machine down and replacing the x-clamps at the same time do the heatgun fix if you dont have access to an IR oven.
To me it will just get worse and will definately need the x-clamps replacing AND the solder re-seating.
hope that helps in some way
www.xboxrepairkit.co.uk
Posted on Sep 26, 2009
HP pavillion dv9000 has black horizontal lines across screen and looks like a snowy background
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the black lines and snowy background, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same black lines ans snowy background it means your video card inside the computer has the issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 18, 2012 | HP Compaq Business Notebook nx7000
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out in solving the problem....
May 21, 2011 | Gateway HD2200 LCD Monitor
Dots on screen
The snowy dots and dots are typically from a poor signal going into the TV.
If there are colored pixels that stay lit all the time (like a red pixel and never goes away) and for any input, that’s called a stuck pixel.
A stuck pixel may be caused by a bad Y-Sustain, Y-drives, Z-sustain, and or a bad plasma panel.
Good Luck.
May 22, 2010 | LG 50PX1D 50 in. Plasma Television
My video looks snowy why?
There are two possibilities to this problem: 1- Your adapter isn't properly connected to your LCD. 2- Your video card is going bad, this happens commonly with all HP computers. I suggest buying a new video card, before your entire screen goes blank.
Jan 24, 2010 | HP Computers & Internet
My tv when turned on goes to a black screen with 3 color strips of lines going across the picture then goes to a snowy picture but only shows on half the screen and then shuts off
This sounds like a vertical problem. It could be just a bad solder joint or it could be a IC that has failed and surrounding componets. Hope this is helpful.
Nov 30, 2009 | Philips 27PT5445 27" TV
My xbox freezes and lines/dots apear on the screen
The graphics processor, and second graphics chip both require a reflow. A special BGA reflow 'heat' machine is required.
FixMyConsole
May 09, 2009 | Microsoft Xbox 360 Console
JVC flat screen digital freeze
what do you have running you cable
Jan 26, 2009 | JVC AV-32950 TV
Lines all across screen. Distorted picture
The it's surge protector is not an issue. Bring up the menu and see if the tv has the same problem. If it does not the problem is your small signal board. If it does and it is more than 1 line the panel could be the problem.
Aug 25, 2007 | Philips 42PF9630A 42 in. Plasma Television
Microsoft Xbox 360 Console Logo
516 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
