Little blue dots on my sony dlp screen.
17 randomly spaced dots, 1/8'' dia. each, same color as blue ray light
on dvd player. they do not move. they do not blink. but they are increasing in numbers slowly. lamp is only 6 mounths old and is not a nockof, it is sony. tv is 4 years old and is in a temp controled, humidity controled, hepa clean room.
  • SD Tech
    SD Tech May 11, 2010
    without knowing model number all I can tell you is it is a bad optical light engine
  • 5,138 Answers
Bad Ljght Engine! CALL UED for rebuilt one 1-800-648-6657
Posted on Sep 26, 2009
Testimonial: "will let you know how it turns out. thanks for advice."
I have gained a sony BDP-S360 Blue ray disc player, but without manual. What are the main parts necessary to adapt this equipmament on my TV? Which cable connections?
start from depending on your tv with hdmi-RGB-s-vid-component that is a little list starting from best to worst just match it up with your tv until you get a color fit and this will rule out best picture too then set tv input accordingly :)
Jan 01, 2011 | Sony BDP-S360 DVD Player
How to unlock region free on U.S sony bdp-s350
Sony BDP S350 bluray - unlocking to region free Yes, it is possible, but you'll need a programmable remote - most use the "one for 3/4/6/all". You can hack it by using the same code as for the bdp-s350. Follow the instructions exactly and it should work - mine does.
Programming the 7040 OneforAll remote to enable region free playback of DVD's on the Sony BDP-S350 Quote: 1. Press DVD 2. Hold the magic button until the DVD button flashes twice. 3. Press 0533 4. Hold the magic button until the DVD button flashes twice. 5. Press 994 6. Press Magic Key (don't hold) 7. Press 1891 (this sets key 1 - the DVD button flashes twice) 8. Hold the magic button until the DVD button flashes twice. 9. Press 994 10. Press Magic Key (don't hold) 11. Press 2552 (this sets key 2 - the DVD button flashes twice) 12. Hold the magic button until the DVD button flashes twice. 13. Press 994 14. Press Magic Key (don't hold) 15. Press 0953 (this sets key 3 - the DVD button flashes twice) 16. Hold the magic button until the DVD button flashes twice. 17. Press 994 18. Press Magic Key (don't hold) 19. Press 2214 (this sets key 4 - the DVD button flashes twice) 20. Hold the magic button until the DVD button flashes twice. . 21. Press 994 22. Press Magic Key (don't hold) 23. Press 0795 (this sets key 5 - the DVD button flashes twice) Done - the remote is now programmed and ready to use Quote: 1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed 2. Make sure there isn't a disc in the machine. 3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing) 4. Put the player back into standby with the Sony remote 5. That's it, the next time you turn on the player it will be region free for DVD playback If the blue 24p light doesn't flash then it hasn't worked, try a new set of batteries and start a fresh Good luck
Dec 02, 2010 | Sony BDP-S350 Blu-Ray Player
I HAVE A NEW SONY BDP-360 SONY BLU-RAY PLAYER AND I HAVE A DVD FROM AMERICA I CAN'T PLAY AS WE ARE IN REGION 2 AND IT IS REGION 1. ANY WAY OF DE CODING THIS SO IT CAN PLAY ALL REGION CODES. THANKS.
Yes there is a hack to make the DVD region free, as far as I know there is not one for the Blu-Ray as yet.
You will need your original remote and a 7040 OneforAll remote to enable region free playback of DVD’s on the Sony BDP-S350.
Programming the 7040 OneforAll remote.
1. Press DVD
3. Press 0533
5. Press 994
7. Press 1891 (this sets key 1 – the DVD button flashes twice)
9. Press 994
11. Press 2552 (this sets key 2 – the DVD button flashes twice)
13. Press 994
15. Press 0953 (this sets key 3 – the DVD button flashes twice)
17. Press 994
19. Press 2214 (this sets key 4 – the DVD button flashes twice)
21. Press 994
23. Press 0795 (this sets key 5 – the DVD button flashes twice)
5. That’s it, the next time you turn on the player it will be region free for DVD playback
If the blue 24p light doesn’t flash then it hasn’t worked, try a new set of batteries and start a fresh
Good luck.
Jan 23, 2010 | Sony BDP-S360 DVD Player
I have blue dots all over my screen aa well as
This blue dot and hue problem is due to bad lcd in your tv as its Sony dlp tv that has optics block, that is also called light engine, it consists of 3 lcds, filters and lamp to produce an image that projects on front screen.
In this tv, blue lcd became defective and complete light engine will be replaced to get it fixed.
As other expert talking about blue CRT (cathode ray tube) that does not exist in this tv and my fellow expert has no idea about this kind of tv, sorry for that.
Hope this info will help you, let me know if you have additional question.
Thanks.
Dec 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
When I try to play a Blue Ray DVD movie I get the
Use a q tip with a little bit (not dripping) of rubbing alcohol. Eject the tray,unplug, look for laser,you may have to do a little bit of disassembling,but have no fear if you have a digital camera at hand. Use the q tip and gently spin it between your fingers and lightly press against the laser lens. Let the lens dry and look for streaking,if it streaks,youre using too much alcohol. After cleaning,test with an audio cd,then regular dvd,then blu ray. If it works awesome,if it doesn't then the laser is most likely burned out.
Nov 01, 2009 | Sony Televison & Video
Letter box picture when viewing blue ray discs on Sony BR player
All blu-ray movies are in Widescreen format. So your tv converts the picture to make it look like letterbox. There will be some movies that will have those little black bars at the bottom. There will be some movies that don't. There is nothing to worry about it is normall.
Hope this helps
Jan 08, 2009 | Sony BDP-S350 Blu-Ray Player
Intermitting blue screen whilst watching my dvd
I'll need more information, but it sounds like an encoded (for copy protection) dvd being played through another device before going to the TV. That intermittent blue screen is usually that. How are you hooking up to your TV?
Jan 02, 2009 | Philips DVP3345V/17 DVD Player/VCR
Blue screen
there's a little button under the screen that turns the screen off when you shut the top look close and flip it till it comes on, they become stiff in some models and don't always pop up so with a little flip it should
Oct 06, 2007 | Durabrand DVD-1002 DVD Player
Televison & Video Logo
981 people viewed this question
Top Televison & Video Experts
