Question about HP PhotoSmart 1215 InkJet Printer
HOW TO GET THE PAGE COUNTER OF HP1215 PRINTER
  • Dave Hamilton
    Dave Hamilton May 11, 2010
    Do you mean the count of the number of pages printed? This is not possible I am afraid, it is not a stastic the printer keeps. People usually start looking for this information when they feel cheated by a companies claims that user will get a certain number of pages before from an ink cartridge. I am afraid from experience that this will always be a loosing battle because pages per print cartridge are based on coverage levels (usually of about 5%)
Hi i have a allin one hp1215 and need to scan with it but not done it before need help please
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. take the test print on the printer and this must be set on the scanner and clicked for ALIGNMENT. This is an automatic process and it will attempt to do it and calibrate. If there is any error , then you need to repeat the process once again.
Thank you for using Fixya
Sep 23, 2011 | HP PSC 1215 All-In-One InkJet Printer
How do you reset the fuser counter, or page counter, on a dell 5330?
There is no mention of resetting the counters during the replacement process in the manual for the printer. (Link below) Try powering off the printer by using a switch or unplugging it.
Manual:
http://support.dell.com/support/edocs/systems/5330DN/en/index.htm
Mar 02, 2011 | Dell 5330dn Laser Printer
HP1215 All-in-One After switched on, the carriage move left - right (start-up procedure) and then go sits in the corner on its base, with the check paper and check print cartridge lights both flashing....
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Oct 29, 2010 | HP PSC 1215 All-In-One InkJet Printer
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
Is there a counter for pages printed on my 1320n
No, the page count is not on the test page. You need the configuration page. Press the GO button and hold for 5 seconds. The yellow light will come on and you can release.
Apr 05, 2010 | HP LaserJet 1320n Printer
Reset maint counter
1. Select Reset Maintenance Count Configuration menu.
Page 3-17 of IBM's service guide
Mar 25, 2010 | IBM Infoprint 1352 Laser Printer
All of the lights on my HP1215 are blinking and the number of copies shows '8' (this is also blinking). I can't turn it off
From HP's support page:
Issue
All lights are flashing quickly.
Solution
  1. Turn off the product.
  2. Unplug the power cord from the back of the product and from the electrical outlet.
  3. Wait 30 seconds and then plug the power cord into the back of the product and into the electrical outlet.
  4. Turn on the product.
Cause
The product has an irrecoverable hardware error.
Jan 08, 2010 | HP PSC 1215 All-In-One InkJet Printer
HP1215 printer says out of paper and won't print
reinstall the printer driver again.and hope the problem will be solved. if the problem still persists then visit below mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP PSC 1215 All-In-One InkJet Printer
HP PhotoSmart 1215 InkJet Printer Logo
195 people viewed this question
Seeker5211
Seeker5211
