When nI try to scan it comes up with an error
When I try to scan it comes up with an error saying it failed to connect to device, I am using a LAN connection, it was working fine prior to this. the error message tells me me to turn the device ON (it is on), check the I/F cable (LAN connection) or wait until the current job is finished (no jobs pending)
When I use the wi-fi connection with the LAN cable provided and run the connection test, all of the tests are successful except for the Viera connection. It is saying the connection failed 006. How do I...
Viera has a set-top box in the TV and the lan wifi router can be connected to cable plant for internet. TV can also send out programs on the set-top box to other wifi receivers. Error code 006 is server failed, Panasonic had a fix on jan11, 2012.
Feb 11, 2012 | Computers & Internet
Trying to connect to internet on my wii console but it comes up with error code 51420
error code 51420 means The Wii console is not able to connect to your wired router or modem.
Try to do this step hope it will help you plzz rate me tnxx...
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
  6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
Jun 04, 2011 | Nintendo Wii Console
Trying to connect with a wired connection that works because i know i use it for my xbox but it says something like code error 51420
not every USB to Ethernet adapter works for the Wii. Here's what I've found from Nintendo's site. You may need to connect with your Wi-Fi and update it first.
Error Code: 51420
Apr 03, 2011 | Nintendo Wii Console
Hello i can't connect to the internet every time i try it comes up saying Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server connection failed.
This is cause because your computer is trying to connect to a proxy server, Try to remove it and then connect
If your using Internet Explorer click on Tools
- Internet Options
- Connections Tab
- Lan Setting Make sure that all the box are untick
- Click ok and then apply
- Open your Browser
Thanks using Fixya.
Jan 24, 2011 | Computers & Internet
I am trying to hook my wii to the internet and it is saying unable to connect error code 51420 and i need free advice or help.
For any help click here
Jan 04, 2011 | Nintendo Video Game Consoles & Games
Ps3 was fine on line this morning but tonight in will not go on line and says error 80130182 i am using a ethernet cable to try and connect can you help ?
Hello, this error means you basically can't get connected to Internet. It's due probably to an IP conflict on your local LAN. Try to do the following: - switch your PS3 off - switch any device connected to your local LAN (laptops, desktops, iphones, etc..) - unplug power cable from your modem/router - unplug ethernet cable from both PS3 and modem/router - wait 1 minute, plug everything right back - switch your PS3 on and see if this error has gone.
Good luck, Peter_Rei
Aug 02, 2010 | Sony Playstation 3 (PS3) Console
While accessing internet through Cricket um185c i am getting an error message that says ''1xRTT connection failed''. i have tried power cycling the comp, flushing and registering the dns, and even reset...
Try removing the device and uninstalling the software, then plug it back in. the setup should start automatically, follow the on screen instructions.
Mar 03, 2010 | FixYa Service
When i try to scan a picture, the hp software opens but then a error box come up saying "an error occurred communicating with the scanning device. Please ensure the scanning device is connected properly...
Try turning the printer off for 60 secounds and see if the reboot will solve the problem. Do make sure all cables are connected properly so your computer will be able to load the correct drivers at start up of the printer.
Feb 11, 2010 | HP Photosmart C5280 InkJet Printer
Errors when scanning via all methods
You just didn't set up the scanner function, please reinstall the software and restart before you use the scanner.
May 15, 2009 | Brother MFC 7420 All-In-One Laser Printer
95 people viewed this question
jasbo
jasbo
