Need winterization instructions for SS Xi 750 Jet Ski, bought used no manuals...I live in wisconsin and need instructions on how to add anti-freeze to system. thanks,
SOURCE: What the best set up for my carb is and how to
is it all stock? what elevation? pre-mixed or oil injected?
SOURCE: 06 kawasaki jet ski wont start
Check the fuses! I have two 900zxi's brand new batteries and brand new plugs,
Fuses are in the electrical box under a black cap(depending on model)
SOURCE: removing starter w/out pulling motor kawasaki jet ski 750 ss
yes but its not easy you pretty much have to take all the exturnal parts off carbs, exhuast airbox if u have one but it can be done make sure you have a swivle for your socketsbest place to get a starter is sbt.com short block tech
SOURCE: I have a 1995 kawasaki
Did you check the 10A main fuse? If it doesn't turn over at all, this may be your issue.
SOURCE: 1995 kawasaki 750 jet ski
Check your plug color. You may be having a high speed mixture problem. Is your ski spitting water out the tiny hole on the side? You should try flushing the engine, you could have a motor full of sand if you beach the craft but do not wash the sand out of the back before starting. Also inspect the engine water tubes for cracks. From the hull to the motor and from the hull to the jet pump.
