Question about Lands Phones
Panasonic DECT 6.0 - continuous ring
Recently, when a call is incoming, instead of intermittant ringing, we've started to get one continuous ringing sound. On the caller's end, they hear the normal intermittant ring, stop, ring etc. But on the receiving end, it's just a nonstop ring. We have the 5 receiver set. it seems like not every handset is doing this, but at different times, all handsets have had the problems.
SOURCE: No ring on handset
It may have lost the link to the base unit. Make a note of all the personal details, stored number, etc., then reset the handset. Do this by pressing the spanner button until the display changes, then press and hold the 'R' (delete) button until the handset resets. You'll have to set it up again, but at least it will link.
Spanner then 1 for ringtone, CID for volume.
Spanner then 2 for keypad bleep, 1=off, 2=on.
both cases press spanner to confirm changes.
Posted on Dec 04, 2007
SOURCE: GE dECT 6.0 Cordless Model 28112 Series
phones say do not disturb and will not ring
Posted on Feb 28, 2008
SOURCE: GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Posted on May 30, 2008
SOURCE: GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
Posted on Jul 09, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
Calling number doesn't announce or show on phone
most phone companies you have to pay extra for caller ID
Oct 12, 2017 | Lands Phones
Answering Machine Problem
You have not configured the phone. If you do not set the number of rings before switching to the answering machine, the phone rings ten times then goes to the answering machine.
Aug 20, 2014 | Panasonic KX-TG6441 DECT 6.0 Digital...
Our phone is not ringing for an external calls but the light is blinking indicating that there is an incoming calls, but calls coming from intercom does ring! meaning our phone is not in silent mode and i...
There are many features which can cause the phone not to ring when incoming calls are on the line. There is a do not disturb key and a mute button on the phone itself. Check to make sure they have not been set. There is an incoming call feature that sometimes needs to be programmed on the phone before it will ring for incoming calls. There is also an automatic answer function that can interfere with ringing too. Instead of listing all of the possibilities, I am including a "cheat sheet" with all of the features & programming for your phone below. Click on the link and scroll through the options to troubleshoot this issue.
If you have any questions please use the comment or reply link near your question on Fixya's website to contact me and I will continue assisting you until this issue is solved.
Sep 14, 2011 | Panasonic KX-T7730 Corded Phone
How do i program the panasonic kxt-7731 so when a call is coming in i can just lift the handset to answer instead of pushing the co line
You have to do 2 things: Make it ring and turn on Line Preference-Incoming Ringing line. The first is done from SYSTEM programming in programs 408/409/410 for DAY/NIGHT/LUNCH. The second is defaulted to Ringing so if the phone rings, it's supposed to work. If you've changed it, then from your idle phone you press PROGRAM and dial 22 STORE. (21 is no preference and 23 plus a number is a specific line).
Carl
Apr 26, 2011 | Panasonic KX-T7731 Corded Phone
Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Apr 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
Panasonic Kx-F2700 Ans/Tel/Fax has a constant ringing sound
hi there.
can some one please help us, we have 8 yr old kx-f2700,it was perfict but now it stop ringing and there is no any identifacation of ring on screen of some one ring us up.there is not any problem out going call/incoming call but the ring.battries ar new and no any error message, the volume is high 8 but still not ringing. thanks
Sep 26, 2008 | Panasonic Office Equipment & Supplies
Intermittently my iPhone does not ring and incoming calls get forwarded.
Through the iPhone to dustbin and buy a normal phone. It works better than this iphone. This happens to a lot of people.
Jul 14, 2008 | Apple iPhone Smartphone
KX-T7730, all the phones connect with operator ring at the same time when having an incoming phone
please i need your help,i use KX-T7730 in my office and of recent when incoming calls comes in all the phones in the office starts ringing and also i would like to know how i can lock and unlock the phone so as to prevent other users from accessing it.Thanks
Apr 10, 2008 | Panasonic KX-T7730 Corded Phone
Uniden DECT 6.0 2080-2 rings for no reason
These DECT 6.0 phones work on 1.9 Ghz frequency and should not have any interference other than from another DECT 6.0 phone that can be within 150 ft of your phone. That means that somebody, a neighbor that has a DECT 6.0 phone close by is causing this problem. It also means that they are also getting these phantom phone rings. The best solution? Go to a 5.8 Ghz phone and your problem should go away.
Mar 13, 2008 | Panasonic KX-TGA101S Cordless Handset
Lands Phones Logo
199 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
