Question about Canon PIXMA MP210 Photo All-In-One Printer
The scanner does not work, printer does and communcates with the pc but the scanner not what do i have to do
How do I get the scanner to work on my computer
your printer probably has a software to install.
this software has the mode to scanner and to scan. the pc has a printer connection right? and.... how to scan should be on the software for the printer. it recognizes the printer and it's looking for a scanner, this is why is telling you scanner connection under the scanner connections but if the use is with the printer as a scanner, it must've a software. maybe the printer a scanner button so the pc recognizes it as scanner.
Jan 22, 2015 | Office Equipment & Supplies
DELL TOWER COMPUTER NOT COMMUCATING WITH PRINTER
Try reloading the printer drivers. You do still have the drivers that came with the printer, right?
Jun 12, 2014 | Dell Computers & Internet
Canon IR2230 is givng an error E000732-0001 and is saying to shutdonw and restart the Printer. Pls help
There is an error in the communication with the scanner.
0001 There is a DDI-S communication .CHECK THE COMMUNCATION CABLE
Mar 08, 2010 | Canon imageRUNNER C3200 Copier
Printer keeps saying can not communcate checked and repug cords
Try turning off printer, unplug printer, turn off computer, plug in printer, turn on computer, turn on printer- in that order. It will all reset.
Dec 20, 2009 | Lexmark X2600 InkJet Printer
Communcation problem from computer to printer
Try to Reinstall Printer Driver. This will be fix your issue.
Nov 23, 2008 | Lexmark Office Equipment & Supplies
Printer model HP color 2605dn does not print from PC
its a communcations problem, make sure the USB or network cable are attached to usb cable computer, network cable to wall jack or hub.
it can also be a driver issue.
is the printer connected via network or usb?
Nov 21, 2008 | HP Office Equipment & Supplies
Printer can't send or receive faxes
Same problem here - I got it work:
- Error Correction: off
- V34: off
(both Menu -> Fax-Setup - All Faxes)
- detect-dial-tone: off
(Menu -> Fax Setup - Fax Send setup - detect dial tone)
:-) Stefan
Aug 30, 2008 | HP LaserJet 3055 All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
159 people viewed this question
old marine
old marine
