Question about Casio Watches
I WAS REPLACING battery on my CASIO G-2210 G-SHOCK watch and a small spring fell out and i can not work out where it goes? can you shed some light on my delema please,
    Problem Solver:
  • 10 Answers
Check out this YouTube video. The small spring is for the alarm.
http://www.youtube.com/watch?v=ogCz2vjUKVg
Posted on Jul 14, 2010
  • 58 Answers
The spring really isn't that important mine fell out too and it works perfectly fine
Posted on Jan 02, 2010
  • Yolanda Heitman Nov 26, 2010
    The spring is what makes the alarm work.
When replacing the battery in my Citizen 8946-095604-ta a small spring fell out ,could you please tell me where it goes, thanks
it goes in a small hole in the back of the movement of the watch and connects to the back plate when replaced to operate the alarm.
Nov 28, 2012 | Casio G-Shock GW500A-1V Wrist Watch
I am changing the batteries in a Casio model 2271 watch. A small silver spring fell out during disassembly. Can you tell me where it goes back?
just bring your casio watch to casio service center, i'm sure they have what you are lookin for.
Jul 14, 2011 | Watches
Looking fo ra parts break down for the DW-9052 Casio. Was replacing the battery and the spring and a little metal tab fell out. trying to find out where they go.
if its a tiny little spring then those springs you will need to put them in a little hole on top of the movement so they press up against the back of the case when y ou put it on . I am not sure what metal tab you are referring to , but I am pretty sure it is the tab that goes on top of the battery and holds it down.
Oct 14, 2010 | Casio DW9052-1V Wrist Watch
Re-assembly
With the stainless back off you can see the white plastic cover. To the right of the large battery is a small hole (about 1.5mm in diameter). The spring goes in this hole and presses against the piezo sounder disk that is glued to the inside of the stainless back. Make sure you put the back on the right way up - the word CASIO should be at the top, the same end as the word ILLUMINATOR on the front.
Apr 11, 2009 | Casio AW43-7E1V Wrist Watch
Can't remember where the little spring go in the g-shock 300
The used of the spring of your watch is for the speaker connection of the back cover of your watch. Your watch is still working even without the spring but no sound of alarm or whatever sound feature.Just go to watch service center im sure they have spear for the spring if not they can make spring from the watch spring bars.
Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Jan 26, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Model & spring issue with an ol casio G-Shock when replacing batt
This spring is connector to caseback for transmitting sound. Get an eyeglass and find out on movement backplate written SPRING COIL and put it back. If there is no marking SPRING COIL then check for the hole with approx. same diameter as spring (must easy fit in). The hole shoud be empty with contact spot at the bottom. Put the spring in and close the caseback. Check alarm sound. If it works, you did find the right hole- if not, try again till you find the right one.
Good luck
Arthur
Dec 13, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
Aug 20, 2008 | Casio PRG-40T-7 Pathfinder
Loose spring popped out from behind....now I have no sound!
this video will show you were the spring goes next to battery
Jun 14, 2017 | Casio G-shock G2300B-1V
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Hi I have a casio g-shock DW9400 and I lost some small springs inside when I tried to change the baterry. Where can I get some help for this? I live in Montreal Thx Dan
i too lost the spring-
ive just got it working by basically using half a staple bent so it contacts the back plate-
works fine.
hope this helps
Apr 12, 2008 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Watches Logo
1,158 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
