Question about Nikon COOLPIX S200 Digital Camera
The same thing happened to me tonight!
My friend accidentally dropped my camera too
When turning on the camera it makes a fast tapping sound and then comes up lens error. Now this happened after i accidentally dropped my camera. Its an S70
When the camera gets dropped it causes all kinds of problems, from your description the lens has been damaged and is seized. To have this repaired would not be cost effective, cheaper to replace.
Apr 15, 2011 | Nikon COOLPIX S70 Digital Camera
When I go to turn on my polariod i733 digital camera the screen stays black and beeps three times. It never turns on. What could be wrong and how do I fix it??
i don't have a solution for you, but i am definately bookmarking this page in the hopes that someone will post one...i dropped mine tonight and it is doing this exact same thing!!!
Apr 05, 2010 | Polaroid i733LP Digital Camera
My ps3 freezes in the middle of games and movies. And sometimes it doesn't even play the movie.
Hey guys i had this same problem 2 times the second time being tonight and i fixed it both times! I don't usually post on forums but im just trying to help out here i know it can be really frustrating when this happens. Anyways what i did to fix the problem is lift the ps3 a couple inches off the ground and gently drop it so the dust or w.e it is in the ps3 settles n fixes. The second time this happened (tonight) i tried dropping it again and it didn't work, it really got me mad, but then i tried dropping it again this time upside down and after 1 drop it worked. anyways hope this helps :)
If i am helpful to you, please rate me.
Aug 11, 2009 | Sony PlayStation® 3 (80GB) Console
Cannot un-ignore fable 2 friend
This has never happened to me but the only thing that i can think of is, try to remove that friend and then adding them as a friend again.
Feb 28, 2009 | Microsoft Fable 2 for Xbox 360
Accidentally dropped digital camera now can't get it to turn on.
I did the same thing with the same result. The only solution is to take it to a repairer, but check the cost first - it might be cheaper to buy a new camera.
Sep 02, 2008 | Cameras
Lens Sticking
The same exact thing happened to me when I accidentally dropped my camera on the ground. My dad actually fixed it for me. I cannot exactly remember what he did, but I know this can be fixed! =]
He did something with the lense, not sure, I wish I could remember!
Jul 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Pls..help me
your friend is probably right try your best to go to another store and see what the prombelem glad to try to help u hope u can find the problem bye
Jun 25, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Dropped my M753 in the water
give it plenty of time to dry out and try it to see if it works
May 24, 2008 | Kodak Easyshare M753 Digital Camera
My optio was dropped with the lens going down first. now my camera makes noises & the screen is black. how do i go about fixing it?
looks like the gears or retracting mechanics are damaged.
its problably not worth to take it in, to get it fixed (depends on the camera). but most likely sound like the gears are busted.
you be paying for repairs that costing waaay more than the camera.
May 20, 2008 | Kodak Easyshare M753 Digital Camera
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 17, 2008 | Canon IXUS V2 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
61 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
