Question about Panasonic SC-BT100 Theater System
Having problems with a Panasonic Home Theatre system. I don't get any sound until I reach like volume level 20 or higher through the speakers. Model of the system is the SC-BT100.
New sky hd box(28/06/11)...sound from tv and sky come through speakers, sound from tv is louder then sound from sky box, bought a optical cable made no difference
Posted on Jul 05, 2011
  • 360 Answers
Http://panasonic.jp/support/global/cs/db/download/bt100/bt100 na.html
for update
Posted on Sep 26, 2009
  • 1 more comment
  • Richard Klein
    Richard Klein Sep 26, 2009
    Let's try re adjusting speaker level
    http://service.us.panasonic.com/OPERMANP...
    go to pg 34 and ref pg 26
  • Richard Klein
    Try to follow the instructions in the manual. I know it isn't easy and complex but, I will work through it with you. Any question just add a comment on this posting will give you a hot line right to me.
  • Richard Klein
    Have you noticed the procedures at the buttom of pg 34. Let me know if your having trouble.
Sony BDVE870 Low Volume
use equalizer to increase volume
May 19, 2012 | Sony Audio Players & Recorders
I have a LG Record reciever home theatre model is LH-RH9691 and im having a problem with the volume only when the radio is working. It can only turned up slightly when set to max volume. But when...
in lg home theater system in video mode the complwte speaker will work and in mp3 only two will word .the radio get only a min volume in lg due to the range of antina
Apr 25, 2011 | LG Audio Players & Recorders
I have a panasonic home theatre model sa-ht900. everything plays fine but i have absolutely no sound at all.possible solutions?
http://www.retrevo.com/support/Pioneer-VSX-D510-Receivers-manual/id/385ci969/t/2/
≥Check the connections.
≥Turn the volume up.
≥Turn muting off.
≥Switch off the unit, determine and correct the cause, then switch the unit on.
Causes include:
-Shorting (bare wires touching) of positive and negative speaker wires.
-Using speakers with an impedance lower than that rated for this unit.
-Straining of the speakers through excessive volume or power.
-Using the unit in a hot environment without proper ventilation.
Jan 30, 2011 | Panasonic Home Theater System System
Panasonic home theatre keeps making a popping
try cleaning all your connections for your speakers with isopropyl alcohol and a q-tip, if no luck it could be an internal problem
Jan 09, 2010 | Panasonic Home Theater System System
I can't get surround sound from my theatre system
Read your manual , there is a level setting for each channel as well as a test function. Also remember most media on pro-logic mode dont have to loud sound from the rear speakers. Only a forced mono mode may give you louder sound at the rear. Regards PSP
May 12, 2009 | Audio Players & Recorders
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
Jan 07, 2009 | Sony DAV-SB500W System
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
Yahoo YHT 630 problem
This is the way speakers sound on most theatre systems. It just depends on how much power is in the system itself. The more power the better the sound. If you have a button on your remote that has the word 'LEVEL' on it, press this and you can change the power that goes to each speaker.
Aug 29, 2006 | Yahoo YHT-630 System
Panasonic SC-BT100 Theater System Logo
433 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
