Question about GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer
Washer not agitating,it doesdrain but does not agitate
    President:
  • 942 Answers
Hello
You need to check and test the lid switch, The lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine. For this reason, the lid switch should never be bypassed.
Test the switch for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.
Inspect the motor coupler,
Inspect the driver belt (belt drive only)
Inspect under the washer for soot (clutch)
Test the motor
Inspect the pulley
Test the transmission
Inspect the agitator
Inspect the pump coupling
Test the water level switch
Regards
PCmania
Posted on Sep 26, 2009
How to remove the agitator
Washer Agitator Repair Agitator Not Working ... - YouTube
? 7:51
www.youtube.com/watch?v=yxfDICZ0Ses
Apr 21, 2010 - Uploaded by applianceassistant Washer Agitator Repair Agitator Not Working Repair ... of a whirlpool built washer, manufactured under the appliance brandsMaytag, Amana, ... How To Repair Washing Machine Agitator -Remove And Replace Agitator Dogs ..
Sep 14, 2015 | Washing Machines
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Ge frontload washer seems like it is not aggitating... what would be the problem???
    Hello there:
    The first thing to check when your GE washer is not agitating, is the belt. Let me tell you how to check the belt & the clutch with out having to take the washer apart.
    The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
    If the washer drains the water and then spins the way that it should, this tells you that the motor, belt & clutch are not the reason why your washer won't agitate.
    A broken belt could be the reason your washer is not agitating or spinning.
    The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
    The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
    Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
    The clutch: A bad clutch could also be the reason the washer won't agitate or spin. Usually when the clutch is bad the washer will be noisy, like when you have bad brakes on your car.
    The transmission: The transmission could be the reason your washer is not agitating. A common problem with the transmission is oil leaking right on top of the motor pulley and the belt.
    As you can see, there could be different reasons why your GE washer is not agitating. You just need to keep checking each part until you find the problem and replace the part responsible.
    Oct 03, 2010 | GE WSXH208A Front Load Washer
    How to remove agitator from GE washer? Model WHDRR418G1WW.
    how to remove agitator from GE hydrowave washer machine?
    Feb 27, 2010 | GE WBSR3140DW Top Load Washer
    How to remove agitator cam from the upper part of the agitator?
    Had same problem with my washer. Check to see if there are little plastic tags holding top/bottom of agitator. after replacing dogs just ensure that you realign with tags so they do not break off.
    Oct 10, 2009 | Whirlpool LSN1000LW Top Load Washer
    Whirlpool washer agitates but makes a very loud noise
    It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
    Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer will not agitate but will spin
    It sounds like the plastic inside the agitator cog are worn. The smell is the plastic cog turning but the agitator not turning.
    Take off the top of the agitator. If any screw are available remove them. If not grab the agitator from the bottom and yank off. Unscrew the agitator drive cog and inspect underside of agitator. Go to an appliance repair shop and reorder a new one. Between $15-30.
    Mar 05, 2008 | Frigidaire GSTF1670A Front Load Washer
    A wears out clutch might prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. Good luck!
    Feb 11, 2007 | Kenmore 15864/15862 Top Load Washer
    GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer Logo
    152 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
