X1190 won't print - Office Equipment & Supplies
Lexmark x1190 makes loud noise
It can be paper jam..check it first..
I think the problem of broken carriages is caused by the ink cartridges being inserted improperly. Be very careful and hold on to the carriage bar when inserting a cartridge, don't jam it in.
I think you should contact with manufacturer...
Dec 27, 2012 | Lexmark X1190 All-In-One InkJet Printer
Lexmark x1190 with windows 7 print queue wont clear after printing
Once you load the driver successively then don't try to fiddle with driver. Remove the printer from the system and switch on whether the printer
initialize proper, try to print one self test page.
Jul 24, 2012 | Lexmark X1190 All-In-One InkJet Printer
When i try to uninstall my lexmark x1190 it comes up printing not finished
Try to clear the Lexmark print queue from pending/stuck print jobs so you can successfully uninstall the Lexmark software/ printer driver. Here's how:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
After successfully clearing the print queue, uninstall the printer software by going to Start menu > Programs > Lexmark 1100 Series folder > Tools > Uninstall. Reboot your pc when prompted.
Hope this helps.
Apr 30, 2012 | Lexmark X1190 All-In-One InkJet Printer
Lexmark X1190 problem communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
Dec 20, 2011 | Lexmark X Office Equipment & Supplies
Need to find a way to get my lexmark X1190 printer to be compatible with macbook OSX Lion
I regret to inform you that the Lexmark X1190 printer is not compatible with Mac OSX Lion. Please contact Lexmark Technical Support Center for other options.
Aug 23, 2011 | Lexmark X1190 All-In-One InkJet Printer
I've installed Microsoft Windows 7 and and now I can't install my Lexmark X1190. What ca I do?
Unplug the Lexmark printer from your computer. Uninstall any existing Lexmark X1190 driver from your computer by going to the Start menu ? Programs ? Lexmark X1100 Series ? Tools ? Uninstall. Reboot pc when prompted.
When your computer turns on, check the System Type if it's 32-bit or 64-bit by going to the Start menu ? right-click on Computer ? Properties. Take note of the System Type.
Use Vista driver in Windows 7. Click on the links below to download the Lexmark X1190 from the Lexmark website.
Download, execute the file and follow the instructions in the software. Thanks.
Nov 21, 2010 | Lexmark X1190 All-In-One InkJet Printer
Can i print on glossy paper with my Lexmark X1190?
You should be able to print on any paper as long as it fits in your printer.You will have to go in to your printer preferences and change the paper type.
Aug 28, 2009 | Office Equipment & Supplies
Lexmark X1190 cartridge hits extreme left side & no print
take the print cartridges out , switch off ur printer. wait 5 min. switch it off again. and put cartridge back again.
Apr 24, 2009 | Lexmark X1195 All-In-One Printer
Poor printing
make sure that the paper is right in the mid
Feb 15, 2009 | Office Equipment & Supplies
26 people viewed this question
jasbo
jasbo
