D-Link DIR-628 wireless connection flickering
I have a D-Link DIR-628, with 2 computers(wired) and 2 laptops (wireless). on the wireless connections, it will randomly flicker, and it will come up and immediately reconnect.When it gets reconnected, any video i was watching will not load past the point from where it dropped off. The wired connections don't seem to have this problem.
  • 32,281 Answers
You are getting some kind of elecrical/wireless interference. This is difficult to trace. Have you noticed any electrical interference on the TV screen when the wireless connections drops off?
It could be as simple as someone using an arc welder in your area.
Or a neighbour heating up something in their microwave oven (this oven can be faulty and is leaking microwave energy).
If you can identify the source of interference then you may find a solution.
There are a few things you can try.
Get a surge protection power board and connect your computer equipment and wireless router to this power board.
You can configure the wireless router to a different channel, one that is not used by your neighbours so that the wireless signal won't interfer with each other.
Have a look at the signal strength to your computer, if it is weak then move the router away from walls and/or raise the router to a higher location to improve the signal strength.
I hope this info helps you fix your problems.
Posted on Sep 26, 2009
Testimonial: "switching the channel seemed to work, thanks for the help "
I can not remember my password for my DIR-628 Wireless Router what can I do
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
kindly rate this post
Jan 02, 2012 | D-Link DIR-628 Wireless Router
Cant connect to dlink dir 628..
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jun 09, 2011 | D-Link DIR-628 Wireless Router
Cannot connect to dlink dir 628 router, why?
Try RESETTING the router.
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
I have a D-link model DIR-628 and I want to use it for direct my wireless printer, the printer setup ask me for the WAP passphrase to end configuration but I don"t have it. How can I get it?
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the wireless printer, or laptops or computers needs to be configured withthese router's wireless settings. Then the wireless printer, laptops and desktop computers cancommunicate with your wireless router.
Mar 11, 2011 | D-Link DIR-628 Wireless Router
I need to connect to a secure network at my sister's home. She has a d link dir-628. I have a dell laptop. I am using the Intel proset wireless to connect. I put in the WPS number and it gathers some...
disable WPS in the router and setup wpa keys (passphrase by hand much easier and you don't have to setup every single computer yet again when you want to add another one)
Oct 15, 2010 | D-Link DIR-628 Wireless Router
How do you connect D-Link DIR-655 router if using an Apple computer? The Apple computer is currently connected to the modem. I have purchased a Dell laptop PC and want the PC to be connected on a...
1. Router's LAN1 connect to Apple through Ethernet cable.
2. Open your Dell Laptop's wireless network connection and search the network and then you can connect your Dell laptop to your router through wireless connectin.
Apr 02, 2010 | D-Link Xtreme N DIR-655 Wireless Router
My PS3 says that I have 100% signal stength to internet. I don't have the WPA key to get in when I try to connect wirelessly. I am renting a condo and the owner forgot the passphrase. I do have the...
connect to the computer via lan cable, acess the configuration utility by typing the ip adress in the web adress box and then choose the wireless sucurity tab.
Mar 06, 2010 | D-Link DIR-628 Wireless Router
Computers & Internet Logo
321 people viewed this question
David Payne
David Payne
