Question about Nikon D90 Digital Camera with 18-105mm lens
Nikon D90 Built in flash will not stay in locked position.
I've had my Nikon D90 for about a month and after approximately 700 shots, the flash will not stay in locked position when pressed down. I explained the problem to Nikon and they said to send it in to their repair facility. I hope this doesn't happen often as the UPS shipping with insurance was $67.
  • brianof5 May 11, 2010
    Hi alaskaangler, Did Nikon fix the problem?
  • 35 Answers
Are you in Auto mode.
Posted on Dec 28, 2009
Nikon D90 flashed CHR and next time using camera LCD was black/grey with stripes and no pics HELP!!!
The CRH error message means that the lock tab on your memory card is in the locked position. The purpose for the lock switch is to allow you to set your SD card so that you cannot accidently erase your valuable pictures. Remove your SD flash memory card from the camera and hold it in your hand with the label toward you and the angled corner to the upper right. Look on the left edge of the card and you will see a very small slider switch. Make sure the switch is in the fully up position then reinsert it in the D90. If the camera is not generating a false error, your camera should work correctly.
Jun 19, 2011 | Nikon D90 Digital Camera with 18-105mm...
I have a quantaray qtb-7500a for an older n80 nikon but i want to use it with my d90 it has a af module nk
The QTB 7500A will work with the D90. However, you will not be able to use the iTTL mode of the D90. Use it exactly the same way you've been using it with the N80, letting the flash control the exposure.
May 10, 2011 | Quantaray QTB-7500 for Nikon TTL Flash
My nikon d90 built in flash does not fire flash. what is the problem?
I have this same problem. Just started this month. Camera is nearly 1 year old and has had very light use. Sorry, not a fix (yet).
Nov 19, 2010 | Nikon DSLR D90 Digital Camera
Got my Nikon d90 for 3 months now,but encountering error problem with my Nikon D90 w/ 18 105 vr lens.sometimes when i'm ready to shot it appears on the Top LCD,error F--,..Pls. help guys...Thanks
This is a common problem with this camera/lens conbo. I "solved" it by removing the lens, then reinstalling it - but hold the lens release button down, and rotate the lens a nuber of times (in the camera body) before releasing the button. It appears that the issue is poor electrical contact between the lens and camera body. If there is a poor contact, the camera will not know if thereis a focus and will lock the shutter release. With this poos contact, the camera will only fucntion in manual mode
Hope that this helps
Aug 31, 2010 | Nikon D90 Digital Camera with 18-105mm...
I have D90 dslr camera last few months was working very fine but last days its shutter not opening propely after click only half image show
Your mirror is not fully opening, make sure you have no dust or object jamming the mirror. Do a cleaning with the mirror locked up in the raised position.
Mar 23, 2010 | Nikon D90 Digital Camera with 18-105mm...
Built-in Flash will not lock down:
There's a latch on it that should hold it down, as long as the shutter release isn't pressed with a need for flash. In the manual modes, it only fires when you release it up, so it should always stay down when you push it down in the those manual modes. FOR SURE, if it won't hold down when the camera is off, the latch is broken.
I'd take it back to Nikon and tell them to fix it. There's really no way to break it through use unless you stuck something in there, which is not likely.
Sep 15, 2009 | Nikon D90 Digital Camera with 18-105mm...
DSLR D90 Built in Flash Will not Stay down..
I know this late but for anyone else who's had this problem. I just fixed the flash on my camera by using a really small1.2mm flathead screwdriver. The problem is that the mechanism that's supposed to catch the hook has gotten off center. Just stick the screwdriver into the little hole on the left side of the flash (right side when looking at it) and then as you turn it you should be able to see the object that's supposed to be catching the hook. Make sure that object is in the correct position and your camera should work again. Hope this helps!!!
Aug 08, 2009 | Nikon D90 Digital Camera with 18-105mm...
My Nikon D90's built in flash is up and will not click back down.
I bought a Nikon D90 camera three months ago. Just yesterday I was using the built in flash. After using it the built in flash won't close. I did not drop it or bang it on any surfuce. I hear alot of people has the same problem. How can I fix this?
May 09, 2009 | Cameras
D90 flash
I have just fixed this problem on my D90. Go to http://dieselpic.wordpress.com/2010/07/14/d90-flash-wont-stay-down-how-to-fix/ to see how I did it.
Apr 08, 2009 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 rear curtain sync will shoot flash twice
That is most likely the TTL preflash and should not show up in your final exposure.
Try setting the flash control to manual (e2 under the Bracketing/Flash menu). That should give you only the one flash at the end.
Aaron Gum
Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 Digital Camera with 18-105mm lens Logo
343 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
