Question about Sony DCR-SR60 30GB PAL Handycam Digital Camcorder
Stuck on clock set screen
It doesnt matter whether I turn the unit off or push the reset button or take the battery out and back in, the camcorder screen stays "stuck" on the clock set screen. Pressing "off" or "ok" on the screen is non-responsive. I am unable to record, playback, take photos or anything else. The up and down arrows work to change the time zone but that is all I can make it do. The camcorder is currently unusable. It was working fine up until this problem mysteriously arose.
  • 188 Answers
SOURCE: camcorder
if all the indicators i.e. battery condition, play mark, counter, etc are visible on the screen then it can be a simple problem of dirty video head. try using a head cleaning cassette or do the head cleaning manually, Open the cover by removing three screws on the right hand side next to the viewfinder. Slide it little towards front and pick it up. The video head will be visible.
Posted on Sep 15, 2006
  • 944 Answers
SOURCE: Camcorder jittery image
How many times did you clean the head? and what with? often you can irrepairably damage the head on these machines by overcleaning. How much difference did the head cleaning make? What was "bad" about the bad tape? was it old/got wet/left in sun/etc....? Are you sure none of the missing screws are still in the machine? Are you getting the same results if you play back using a different camera/player or have you only tried your camera? Are there any unusual noises when the camera is recording or playing back? - listen really really carefully, in case there is a motor or gearing problem. Waiting for your info :)
Posted on Jul 21, 2007
magic seadog
  • 38 Answers
SOURCE: Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Posted on Aug 19, 2007
SOURCE: camcorder
lcd screen blank
Posted on Feb 08, 2008
  • 10594 Answers
SOURCE: DCR-HC19E Camcorder LCD Screen not Working
DCR-HC19E has cracked/ broken flexible cable, connecting LCD and main camera board.
Posted on Jul 25, 2008
My phone is frozen! It is stuck on this msg. "Samsung SGH-T249". No matter which button I push, nothing happens. It will not turn off, nor can I make outgoing call. The screen stays...
Press and hold the power button until the unit turns off. Sometimes it takes up to two minutes to turn off. If you cannot get it to turn off using the power button, open the back and take the battery out. Press and hold the power button for sixty seconds with the battery removed to reset the unit. Then reassemble it and turn it on. This may not solve the problem on why your screen is getting stuck but it will reset and allow you to attempt to restart it.
Aug 16, 2011 | Cell Phones
Our Skyscan atomic wall clock will not stay at the correct time since we had the daylight savings time. I replaced the battery because each day at noon it would randomly reset it self to the old time (1...
take the batteries out and leave them out for at least a minute. when you put the (new) battereis back in be sure that you have the correct time zone pushed and if there is a DST button or switch make sure that is pushed/set as well. place the clock with its back facing colorado and leave it overnight, it should reset itself ok.
Mar 17, 2011 | SkyScan 86709 Atomic Wall Clock
I am having trouble setting my skyscan atomic clock i took the battiers out and need to reset the whole clock.The modle number is 88900-8901
taking the batterys out and leaving them out for 60 seconds or more will in effect reset the clock. Put the new batteries in and wait for the skyscan to detect the outside temperature (if this unit has a outside sender). after this show on the screen push the button that corresponds to your time zone. You can now set the clock with the push buttons or take the clock to a wall that faceing? ( you don't say where you are located), the WMV signalyou need to set the clockto is coming from Colorado USA ( if your in the us) so make sure the back of the clock is facing toward colorado. let the clock sit overnight as the best signal will be recieved when its dark and especially in the very early morning, just before sunrise. this should automatically set the clock for you. good luck
Mar 14, 2011 | SkyScan 86709 Atomic Digital Wall Clock
I have a Sharp SPC502 atmoic clock/weather station. No matter what I do I cannot get the outside temp/humidy to show up on the main station. Have tried changing channels, different alignments,...
Try pushing the reset button on the inside of the battery compartment of the remote unit then push the reset button on the back of the main unit (you'll need a paperclip or tooth pick to push the buttons). If that fails I'd start from scratch by removing the batteries from both the remote unit and the main unit then replace the batteries to the remote unit first and push reset, then replace the batteries to the main unit and if necessary push the reset button on the main unit too. Hope this helps.
Dec 28, 2010 | Sharp Cell Phones
I have a sony dig 8 trv340 and am receiving an error code of c31:42 what does this mean?
In DCRTRV430 Camcorder, the C:31:42 error message is a Self diagnostic display. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camcorder. In C:31:42, the issue is with the tape and the tape mechanism.
I suggest that you remove and reinsert the tape to check if it helps. You may also try inserting new tapes in the Camcorder. Please remove the battery and/or power cable, connect, and perform operations from the beginning. You may also try resetting the Camcorder back to factory default after removing the tape.
To Reset the Camcorder, perform the steps below:
? Please open the LCD screen to locate the RESET button.
? To reset the Camcorder, press the RESET button using a sharp-pointed object.
? Please make sure that the Camcorder is turned on while pressing the reset button.
Also, try turning off the Camcorder and remove the battery pack. Then move the 'Power Switch' of the Camcorder to the ON position
for 1 minute. After about 1 minute, move the 'Power Switch' to the OFF position.
Now reinsert the battery, turn on the Camcorder and check whether it is working fine.
Oct 23, 2010 | Sony Video Cameras
All over sudden my boston horizon doesnt allowe increase the vol.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
May 17, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
Fix clock
hold the source button down to turn off player (i think this is the dial you push and hold in) once unit is off hold the F / Function button down for a few sec the screen on unit will activate press F or function button until you get the clock setting after setting the hrs press f or function again to get to setting the minutes after this is done press the source button (should be the silver dial push it in) now turn the unit back on clock should be set
Feb 19, 2009 | Pioneer DEH-P690UB CD Player
Our borrowed Flip (Ultra?) seems to be frozen ON.
I have the same problem and found something that kinda worked for me. Hopefully it'll work for someone else. Turn on the flip while holding down the - key. It should power up normally and allow you to view/record etc. Several videos say "Invalid Format" or something like that on the screen, but most are ok and I can record. Better than a completely dead one.
Nov 26, 2008 | Pure Digital Flip Video Ultra Camcorder
To make un full reset
Hello Rahooty,
There is no way to set the date and time becayse the system clock in your Garmin Rhino 120 should be updating based on the information it receives from the GPS satellites. The radio should auto locate itself within about five minutes of being turned on providing it has a clear view of the sky. Once it sucessfully auto locates the radio's clock and position should reset. There does not appear to be any other reset built into the device.
Try taking the batteries out for at least 5 minutes. Then, reinstall the batteries, turn the unit on, and give the unit 5-10 minutes to auto locate. If it doesn't, you may need to contact Garmin support for additional sevice.
Best Regards,
"Go Ahead. Use Us."
Jun 05, 2008 | Garmin Rino 120 2-Way Radio
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony DCR-SR60 30GB PAL Handycam Digital Camcorder Logo
48 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
