Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
Making loud humming/engine noise when tv is on even without sound and the color is off..the sound is still going until the bulb is off
  • Samsung Master
  • 5,138 Answers
Bad Color Wheel Call Encompass for Part 1-800-638-3328 Do Not Play TV untill it is Fixed it can cause Damage to Light Engine if it Shatters while playing.
Posted on Sep 26, 2009
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
I have a issue with my rca scenium hd61lpw164yx1 tv ...i have replaced the bulb about a year ago. my screen started not coming on instantly it started fading in and eventually would not come on at all.i...
When the color wheel starts to go there is a high pitched whinning sound, the humming could be from the light engine or ballast, which may or may not be related to the color wheel. I would have to see it and test things for a correct diagnoses, but it does at least sound like a color wheel in the last moments of its life
Jul 16, 2011 | Televison & Video
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
TV making loud humming noise
Sounds like u need a color wheel
Apr 06, 2009 | Televison & Video
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
Tv has what sounds like a humming noise by where the bulb is
sounds like the color wheel problem.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Dec 11, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Nov 30, 2006 | Toshiba 62HM95 62" HDTV
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
253 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
