Question about Nikon COOLPIX L12 Digital Camera
Camera fell down and lense has got stuck, service center is asking new lense would cost Rs6000
    President:
  • 1,197 Answers
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Posted on Sep 27, 2009
Coolpix s3300 lense stuck in
Contact the Nikon USA Repair Center at 1-800-645-6687 9AM-8PM EST, Monday to Friday, for instructions for obtaining a free estimate for repair. Your camera has damage that you will probably not be able to fix yourself.
Feb 10, 2014 | Nikon Coolpix S3300 Digital Camera Silver
LENS ERROR SHOW
This problem happens because of longtime no using/ Dust or Lens guide pin damaged. If the lens guide pin damagethen there is no chance for repairing . Only solution is replacing the lens. For the solution you need to follow the steps.1. Turn off the camera and remove the memory card and clean theexternal body of the camera and make sure in place of the lens there is no dustor damaged sign.2. Now turn on the camera without memory card & make sure thebattery are fully charged.3. If the lens not moving then give a little shake or thrust by hand( carefully very slow) and then wait for a moment. If no changes then turn onthe camera and give a little twist an anti clock side and leave for few second.It is risky ( Do it slowly at your own risk)4. If nothing change then reset the camera setting from the menuoption.After following all steps, if thecamera does not start working then you need to visit service center forreplacing the Lens or Repairing. But before repairing ask service center theapprox cost. if they told you to replacing the lens then do not do that.Because a new lens & service charge cost you near about a new camera price.So best is buy a new camera. If you have any more questions ask me I fell happyto answer your question. Thank you.
Sep 28, 2011 | Nikon COOLPIX S220 Digital Camera
My lens fell down and I think is not broken but the front part is separated, can I repair it myself or should I sent it to customer service?
Get a quote first for the repair as this lens is the least expensive Canon lens and it could be that the combined cost of postage and repair will exceed to cost of a brand new replacement.
Feb 11, 2011 | Canon EF 50mm f/1.8 II Lens
My Nikon Nikkor 18-55mm lens will not automatically focus even when set to "A". I have cleaned it with canned air and the manual focus works fine. I want to repair it myself as Nikon has quoted...
hi there,
the motor inside your lens might have been broken,
was it fell down or hit something before?
if it`s still in warranty, you can claim it to Nikon Service Center
hope this post will help
Jan 05, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Shutter is stuck halfway. when i open the lense the shutter drop. what can i do? please help me. there are no service center in my locality.
shutter is stuck halfway. when i open the lense the shutter drop. what can i do? please help me. there are no service center in my locality.
Dec 19, 2010 | Nikon FM10 35mm SLR Camera
Lense get stuck halfway in, fell on the road, what can I do?
The easy way to repair it without damaging it is to take it to a service center. It is not a costly repair.
Dec 21, 2009 | Canon PowerShot SD600 Digital Camera
Coolpix camera
It needs to be sent in for service. You may be better off buying a new camera since the repair cost will start at $100.
Sep 23, 2009 | Cameras
Help me !!!!
Contact the makers customer support.
The likely cost of repair however will be near the cost of simply replacing the camera.
Get your friend to donate you the cost
Jul 27, 2008 | Canon PowerShot SD1000 Digital Camera
Concerning fuji digital camera F650- how to fix it ..
These things are not servicable Simply replace it .
Jun 29, 2007 | Fuji FinePix F650 Digital Camera
Nikon COOLPIX  L12 Digital Camera Logo
124 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
