Question about Gigabyte GA-8S661FXM-RZ Motherboard
Ive installed 2 gig of memory but only showing 896mb memory
    Sergeant:
    Champion:
  • 232 Answers
You can come accross faulty memory sticks .
just watch out that you have not inserted your memory stick in the wrong slot as some PC boards do have different memory slots side by side
Posted on Sep 26, 2009
Hi all ive got 2 512mb and ive just put in 2 1 gig into purple slots at first all it did was beeb like mad,after taking them out and putting back in the computer as far as windows logo but no further...
You probably need to flash your chipset in order to take that much memory in your pc. What kind of computer is it? what operating system are you using? did you check the specs to see how much memory is the max that your system can take? What chipset is installed? Try removing some of the memory to reduce the load, then flash your bios and reboot. Add the rest of the memory and see if that solves your problem and allows the pc to load as normal.
Oct 15, 2011 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
How do I install more memory in a Gateway GT5464?
Please look into the below link for user guide manual to install Memory into your computer:
Refer to page no: 37: To Install or replace DIMM memory.
Here is the link:
http://support.gateway.com/s/Manuals/Desktops/8512041.pdf
Regards,
Shami
Dec 03, 2010 | Gateway Computers & Internet
Running a 1 gig stick and a 512mb stick, system only shows 896mb, apparently not recognizing all of the ram installed?
I assume that you've booted the computer with _ONLY_ the 512MB stick installed, and that the computer recognized it (reporting either 512MB or 384MB), i.e., the 512MB RAM is not "defective".
Hmm. 1024 minus 896 is 128.
So, the "integrated-into-the-motherboard" video-card is "stealing" 128MB of your RAM, to be used strictly for "video" purposes, leaving 896MB for Windows to use.
Now, about the "missing" 512MB of RAM.
1. If you have four slots for RAM, and they are physically arranged into two pairs of two slots, rather than four equally-spaced slots, your motherboard is capable of "dual-channel" mode. But, since your two sticks of RAM are not "matched" (size, speed), you _MUST_ insert both sticks into _ADJACENT_ slots (not slots 1/3, nor slots 2/4), in order to run your RAM in "single-channel" mode.
2. If you have two slots for RAM, interchange the two sticks, to see if that makes a difference.
Aug 19, 2010 | eMachines W3507 PC Desktop
I just upgraded memory from 512 to 2 gigs, but the computer only shows 1 gig. why?
The other 1 gig is not properly installed oropushed in all the way
Oct 02, 2009 | Acer Computers & Internet
Wont boot 2 windows xp home when 2 gig memory installed,works with 1 gig,tried both slots with both 1 gig sticks.Screen goes black.
Seems the memory is not comatable with the motherboard. Replace the old memory and visit http://www.crucial.com, they have a scanner tool which will confirm what mem can be installed.
Apr 30, 2009 | Computers & Internet
DDR2's only showing half installed RAM
IF THE SYSTEM SAYS YOU HAVE 1GB RAM THAN YOU HAVE 1 GIG OF RAM, EVEN THOU SOMEONE TOLD YOU YOU HAD 2-512MG=1GB.
HERE IS HOW I SEE WHAT YOU ARE SAYING YOU HAVE 2-DDR-2 1 GIG STICKS THAT MEAN IF 1 IS INSTALLED THAN YOU HAVE 1 GB AND IF YOU COULD GET 2 STICKS WORKING TOGETHER THAN YOU WOULD HAVE 2GB RAM.
1 CHIP SET = 1GB RAM
2 CHIP SET = 2GB RAM
YOU MOTHERBOARD MAY NOT ALLOW THAT MUCH RAM, OR WHAT I MEAN THE BIOS MAKE UP THE AMOUNT OF RAM.
TO RULE OUT ANY BAD CHIP SETS OR GOOD RAM OR BAD RAM.
TAKE THE PEACE OF RAM THAT IS WORKING OUT AND REPLACE IT WITH THE OTHER PEACE AND SEE IF IT WILL RUN.
IF IT WORKS THAN LEAVE THAT ONE IN PLACE AND INSTALL THE SECOND PEACE IN THE SECOND SLOT.
IF BOTH CHIP SET ARE GOOD THAN BOTH SHOULD WORK OKAY TOGETHER.
IF THERE IS A PROBLEM, IT MAYBE SOME DUST IN THE MEMORY LOTS
OR THE SLOT MAYBE DAMAGED.
OR
THE CHIP DESIGN LAYOUT MAYBE THE OPPOSITE SIDE, THIS MAY MEANS THE CHIPS MAY FACE EACH OTHER, OR FACE OUTWARD FROM EACH OTHER.
ROD
Mar 14, 2009 | EliteGroup P4M800-M7 Motherboard
Have a compaq presario sr2170nx....installed 1 gb memory but not showing up. swapped the memory sticks positions and restarted but still wont show up.
If you do not get the right memory for your computer it will not work. the memory you need is listed in the table below. And pay attention to the max amount of ram. Your system can only hold 2 gig and it comes with one gig installed
Component Attributes Memory Installed 1 GB Maximum allowed 2 GB (2 x 1 GB) Speed supported PC2-4200 MB/sec Type 240 pin, DDR2 SDRAM
Jan 14, 2009 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
Dec 30, 2008 | Computers & Internet
Ram upgrade
It's generally not a good idea to mix sizes as your more likely to get problems, but that said it probably should still work it's most likely your configuration consult your motherboard book as to what order you should install the memory you have.
Oct 30, 2007 | Intel Motherboard
Gigabyte GA-8S661FXM-RZ Motherboard Logo
70 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
